Hrm. I donāt understand how thatās connected to media being available or not. I agree with
Also, I added some upgraded .mp4 files to existing movies. They got bitrate immediately when they were added.
Then I added some .mkv files, and they didnāt get bitrate immediately. SO Iām going to test that more deeply now.
I added some more MP4 media. Some new, some upgraded encodings. All received bitrate immediately. All received improved estimates after deep analysis completed.
I added some MKV media. Some new, some upgrades. None received bitrate immediately. All received bitrate after deep analysis completed.
@BigWheel does this seem like a bug?
Yeap, I also think this is a bug.
What do you say @BigWheel ? ![]()
Possibly not a Bug, and my initial suspicions are true.
Maybe itās just a strategy to force desktop users to buy the apps.
Not fixed in Plex Media Server 1.20.3.3437
Is is possible to get a sample of one of your MKVs this happens to.
Sure.
This is a sample file that produces the described behavior:
Sample File
If you need any help troubleshooting this issue I started a now locked thread and was able to get to the root cause with the help of @anon18523487 and @ChuckPa. They were each on the cusp of filing a bug report but unfortunately I donāt think it ever happened. Here is the thread:
Plex Incorrectly Estimating Required Bandwidth - Forcing a Video Transcode
The tl;dr was that MKVToolNix (and possibly FFMPEG) changed how they handle audio bitrate metadata for MKVās. Older versions of MKVToolNix used:
Metadata:
BPS: 640000
BPS-eng: 640000
However newer versions simply use:
Metadata:
BPS-eng: 640000
PMS is unable to parse the audio bitrate from the new metadata format. If you attempt to play the file before a deep analysis occurs (or simply have deep analysis disabled) it can cause lots of wonky behavior on a number of clients since Plex āstreaming brainā assumes an astronomical bandwidth requirement due to the blank field
You should be able to recreate an affected file yourself by using the following command on any old AVI/XVID file with a modern version of FFMPEG:
ffmpeg -i movie.avi -c:v libx264 -c:a eac3 movie-h264-eac3.mkv
For anyone experiencing similar issues, me and @Volts have discussed the issue further with some possible workarounds here:
