Bug - AndroidTV Plex does not passthrough ATMOS for ATMOS Music files
Server Version#: Version 1.27.2.5929 (newest as of 30 July 2022) on Windows 7
Player Version#: Version 9.5.0.33736 (newest as of 30 July 2022) on Sony Bravia TV.
  • Same problem exists also with Plex app for Firestick
Problem : Playing EAC-3 ATMOS music files with Plex does pass through ATMOS information to an ATMOS receiver or ATMOS soundbar. To clarify these are lossy EAC-3 “audio only” music files that have ATMOS information (Note - Works fine with Emby). See below for MediaInfo of a sample Dolby ATMOS music file :
General
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1)
File size : 28.2 MiB
Duration : 5 min 6 s
Overall bit rate mode : Constant
Overall bit rate : 771 kb/s
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : ec-3
Bit rate mode : Constant
Bit rate : 768 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 28.1 MiB (100%)
Service kind : Complete Main
Default : Yes
Alternate group : 2
Encoded date : UTC 2021-12-01 18:34:34
Tagged date : UTC 2021-12-01 18:34:34
Complexity index : 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Problem continued : *NOTE - These same ATMOS music files play fine with ATMOS using Emby so we know it’s a Plex bug. Plex Dashboard says these files are DirectPlaying but since it’s not showing up as ATMOS to the receiver or soundbar we know that’s not true. Do you need a copy of this ATMOS music file for troubleshooting purposes? What other info do you need?
NOTE - Video files with an EAC3 Atmos audio soundtrack play fine. It’s just “AUDIO ONLY” EAC3 with ATMOS that don’t.
Cheers
Bump of course… hello plex?
Such helpful people here really, thanks a lot.
In case anybody interested reads my above bug report the “interim answer” can be found here
(Dolby Atmos Music on Nvidia SHIELD). Even though the question/answer is about the shield it pertains to Fire & TV apps as well. Will they fix it? Hahaha, ya right.
