[BUG] Broken play queue functionality since a few weeks ago - Android Mobile Beta
Server Version: 1.24.1.4931
Mobile Version: 8.22.0.27166
Expected functionality
Add a bunch of items to the play queue, either by directly playing a playlist or manually playing an item, backing out and selecting add to queue on a bunch more items. Press play again on “currently playing bar” at the bottom of the screen. The queue should continue to play as it used to before.
Current broken functionality
  1. Add a bunch of items to the play queue, by directly playing a playlist, pause and back out. Press the bottom bar showing what currently is playing, the item goes full screen and paused (which is what is it supposed to), but they play queue is now empty except for that item. Pressing play makes the play queue contain all episodes from the season the item was from instead of the play queue.
  2. Play an item, pause, back out, add one or more items to the play queue by manually selecting add to queue on the items. Press the bottom bar again and a notice comes up: “Play - This will clear the contents of the queue and play the selection instead” and only the current item plays, and the play queue is replaced with all episodes from the season the item was from instead of the play queue.
Impact
Play queue handling is not working at all any more.
I have got the same issue
I’m also having this issue on two separate android devices.
Both are running version 8.21.2.27212
Still having this issue with the latest version 8.23.1.28053 and beta version 8.24.0.28335
Issue still exists with Android app 8.25.0.28636 and server 1.24.5.5173-8dcc73a59.
I’ve had this issue for forever too and I haven’t been able to find anything that fixes it. Server version 1.24.5.5173 and app version 8.25.1.28703.
Still broken. App 8.29.0.30300, server 1.25.3.5409.
Still have this issue as well, android app version 8.29.1.30694 and server version 1.25.5.5492
This is still an issue with client version 9.2.0.32520
