[BUG] Default to using embedded subtitles over agent downloaded subtitles
@OttoKerner said:
Let Sub-Zero store the downloaded subs in their default place, in the metadata ‘bundle’ (which is not beside the video file), then the logic works as intended.
I did not know that would make Plex default to embedded, I will make that change.
What do I do with the 600+ subtitles already downloaded into the directories where the movies are?
I am also for a selectable option to prefer embedded subtitles.
Thanks!
Erase them if they don’t fit.
That option is (kinda) already there. Simply select the right subtitle at the preplay screen of the movie. This selection is stored in your user account.
