BUG, ERROR (networking:197) - Error opening URL
latest server plex version 1.40:
OS: Debian 12 (x64)
Bug in Logs/PMS Plugin Logs/com.plexapp.system.log:
Plex Media Server.log:May 07, 2024 18:42:54.672 [139636710378296] WARN - NAT: PMP, got an error: Not Supported by gateway.
PMS Plugin Logs/com.plexapp.agents.imdb.log:2024-05-07 18:42:41,646 (7fd9daa6c808) :  ERROR (networking:197) - Error opening URL 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/resourceHashes'
PMS Plugin Logs/com.plexapp.agents.imdb.log:  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 473, in error
PMS Plugin Logs/com.plexapp.agents.imdb.log:  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 556, in http_error_default
PMS Plugin Logs/com.plexapp.agents.imdb.log:    raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
PMS Plugin Logs/com.plexapp.agents.imdb.log:HTTPError: HTTP Error 404: Not Found
PMS Plugin Logs/com.plexapp.system.log:2024-05-07 18:42:40,375 (7f8e473fe808) :  WARNING (data:179) - Error decoding with simplejson, using demjson instead (this will cause a performance hit) - Expecting property name enclosed in double quotes: line 26 column 1 (char 1078)
PMS Plugin Logs/com.plexapp.system.log:2024-05-07 18:42:40,454 (7f8e43e1cb30) :  ERROR (networking:197) - Error opening URL 'http://127.0.0.1:32400/:/plugins/com.plexapp.system/messaging/function/X0J1bmRsZVNlcnZpY2U6QWxsU2VydmljZXM_/Y2VyZWFsMQoxCmxpc3QKMApyMAo_/Y2VyZWFsMQoxCmRpY3QKMApyMAo_'
PMS Plugin Logs/com.plexapp.system.log:2024-05-07 18:42:40,454 (7f8e43e1cb30) :  ERROR (services:272) - Unable to load services from system. Loading from the current bundle only.
PMS Plugin Logs/com.plexapp.system.log:2024-05-07 18:42:40,454 (7f8e43dceb30) :  ERROR (networking:197) - Error opening URL 'http://127.0.0.1:32400'
PMS Plugin Logs/com.plexapp.system.log:2024-05-07 18:42:40,894 (7f8e43bc3b30) :  ERROR (networking:197) - Error opening URL 'http://127.0.0.1:32400/servers'
PMS Plugin Logs/com.plexapp.system.log:    return HTTPRequest(self._core, url, data, h, url_cache, encoding, errors, timeout, immediate, sleep, opener, follow_redirects, method)
PMS Plugin Logs/com.plexapp.system.log:  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 473, in error
PMS Plugin Logs/com.plexapp.system.log:  File "/usr/lib/plexmediaserver/Resources/Python/python27.zip/urllib2.py", line 556, in http_error_default
PMS Plugin Logs/com.plexapp.system.log:    raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
PMS Plugin Logs/com.plexapp.system.log:HTTPError: HTTP Error 503: Service Unavailable
PMS Plugin Logs/com.plexapp.system.log:2024-05-07 18:42:41,639 (7f8e43bc3b30) :  ERROR (networking:197) - Error opening URL 'http://resources-cdn.plexapp.com/hashes.json'
PMS Plugin Logs/com.plexapp.system.log:HTTPError: HTTP Error 404: Not Found
@gvrht
Which OS distro is this running on
What are you trying to do here?
(Seeing an error in isolation doesn’t mean much without context)
Yes, sorry. Have modified post.
However this error happens as soon as I start the plex service.
