[BUG] Error when editing playlist filters with "track length"
Player Version#: 4.116.1
I have created a playlist in plexamp using the “track length” filter.
The playlist is perfectly created and is visible both in plexamp and in the plex application (web, for example).
But once it is opened and attempts are made to modify the filters, an error appears.
Exactly the same thing happens to me as this user.
There, a Co-Founder indicated that we should report the problem to the plex-web team.
Thank you.
Thanks for report. The advanced filter list options in Web come from server so that is what I made report for. I can’t promise any sort of ETA for this.
I can put the bug in the plex-server forum if you think it’s a better option.
