Server Version#: 1.42.1.10060 (but present on 1.41.x.xxxxx as well
Player Version#: 4.148.0 (Web on Firefox, tried Chromium as well, same issue)
Let me know if server logs would be useful, but I see no errors popping up except for “Unknown metadata type: folder” which also appears in other instances so I’m not sure it’s an actual error, or if it is, it doesn’t really affect much.
The issue is specifically targeting the Track Duration filter, no matter how I try to edit filters on the Web, no matter which page I access the “edit filters” functionality from, once it tries to open the filters interface it crashes with “Something went wrong” - “An unexpected error occurred.” as long as the filters contain a “Track Duration” filter.
Editing the smart filters from mobile or the desktop plexamp apps works even with the track duration filter. If I remove the filter, the Web UI also starts being able to edit the filters.
(Just checked in the Web UI and I cannot add the Track Duration filter from there, so it seems to me like the issue here is that this “Track Duration” filter is not available in the WebUI, but it is available in PlexAMP, causing the WebUI to crash when editing filters with this specific feature.)
