Can someone fix/adjust the sonic analysis so it doesn’t retain a significant history of files? I just had to clear out almost a terabyte of those folders/data because it had saved the analysis from as far back as 2021. If a history of said analysis needs to be retained, can it be enabled as an option on the dashboard? Something simple: Retained number of sonic analysis, and then an integer field.
Linux?
I think so: Synology DSM
