Bug - Mark As Played/Unplayed not visibly working on pre-play screens
Android TV Beta - 8.3.0.18775
When on any pre-plays screens, if I select the ‘Mark as Played’ or ‘Mark as Unplayed’ it does not visibly toggle to the other state in the way that it normally does (or used to). Neither does the Orange triangle in the corner of the poster art appear/ disappear accordingly.
If you exit the pre-play screen you can see that the selection was acknowledged and that the desired change to watched/unwatched status was made successfully in the background.
Could just be me but tested on multiple clients (same version of app) and the results are consistent.
Same version on NVidia Shield TV, same issue here
Thanks for the report, the fix is on the way.
This issue should be fixed in the latest beta (8.3.0.18867).
I’ve just tested the latest beta (8.3.0.18867) and it fixed this issue for me on NVidia Shield.
However if you display the content library page in “Library” view instead of “Recommended” the watched status on that page doesn’t refresh either until you navigate to a different content library and back again. Is it possible to fix that refresh issue as well?
Hello @marekszulik. The new beta version has fixed this specific problem for me. Thanks for your efforts.
