I have enabled ‘Early Access’ on my LG C9.
Commentary track is playing instead of default audio track. Sometimes a few seconds of the default audio track play before it switches to commentary. This has occurred with multiple files. It does not occur with the stable release. Video and Audio are both Direct Play.
After enabling ‘Log to Media Server’ I did not see any relevant information in the most recently modified files.
Client Version: 5.0.10
Platform Version 4.8.0
Server: Synology DS1019
Version: 1.19.4.2935
General
Unique ID : 197018446663456020190447722584963987624 (0x94385F62E1FB8FF1AA993F40636AB8A8)
Format : Matroska
Format version : Version 4 / Version 2
File size : 552 MiB
Duration : 22 min 21 s
Overall bit rate : 3 454 kb/s
Encoded date : UTC 2013-08-11 11:39:03
Writing application : mkvmerge v6.3.0 ('You can't stop me!') built on Jun 28 2013 20:09:41
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings : CABAC / 13 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 13 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 3 001 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.362
Stream size : 480 MiB (87%)
Writing library : x264 core 133 r2334 a3ac64b
Encoding settings : cabac=1 / ref=13 / deblock=1:-3:-2 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.10:0.10 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=0 / chroma_qp_offset=-3 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=6 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=19.0 / qcomp=0.80 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.10 / aq=1:0.70
Language : English
Default : Yes
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 9 ms
Stream size : 30.7 MiB (6%)
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Bit depth : 16 bits
Title : Commentary
Default : No
Forced : No
Text #1
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : Picture based subtitle format used on DVDs
Language : English
Default : Yes
Forced : No
Text #2
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Language : Spanish
Default : No
Forced : No
Text #3
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Language : French
Default : No
Forced : No
