I am having the same problem. AAC-HE is broken and I have to transcode it to AAC, which seems a waste of resources.
I thought I had similar issue until I figured out the actual mp4 i downloaded contained some blank data streams. So it had Steam 0 video, stream 1 audio HE-AAC, and then there’s stream 3 and 4 data but no data. So I ended up reencoding all those files and stripped those data with ffmpeg.
ffmpeg -i input.mp4 -map 0 -map -0:d output.mp4
These data streams did not show up in the xml in plex. Only when I did mediainfo or ffmpeg -i input.mp4
Add myself to!! Sorry @DaveBinM!! I’ve upgraded to the latest Beta version after having the issue of Plex on Android playback issues like others, but it’s now fixed that, but only by going to Transcode, seems not just HE-AAC audio either??
I’m having issues still with Player not playing certain MPEG4 files on the phone over Local WiFi and Remote WiFi but on 4G/Cell works a treat!! Not sure is rhis a Transcode issue or something else??
Dave
Hey Dave,
Just wanted to check in to see if you had any updates. Thanks!
Not yet, I’m afraid, still under investigation
I can confirm the issue, and also would like to point out that this isn’t restricted to Android devices.
I just found this thread because of the same issue/symptoms on an Apple TV 4k trying to watch a video with HE-AAC audio.
Changing/transcoding audio stream to “(English EAC 5.1)” allowed the video play correctly.
Confirming the same issue here. Fire TV stick 4K
Plex web plays the video fine.
That’s a screen capture of the issue. I need a sample of the original file to reproduce the issue
@Charabel, see this page for instructions on how to generate a sample file:
This might just be an MKV demuxing bug? I put a show that is having this problem through the Optimizer (Optimize for TV) which converts to MP4 and now the HE-AAC is playing just fine on my Android Smart TV.
Dave - see if this works…
Thanks! I’ll take a look this week!
Any update on this?
Dave - any updates on this?
Still bugged for ALL ANDROID CLIENTS. Great showing Plex!
Just because things aren’t in a public release yet, doesn’t mean they’re not being worked on and investigated
It says a lot that this is the one you reply to instead of the status updates people keep asking for.
I was on leave, if you must know. The issue is still being investigated.
I must say I have not seen this issue with a LG Tv using a Mac Server
This issue dates back to 2018. Has there been any update?
