Server Version#: 1.14.0.5465
Player Version#: NA
I have a library dedicated to my DVR so that all shows that are recorded are added to this library. I set my show series to delete after watched. Several of the shows I record, I also have previous seasons stored in another library. When the delete when watched is enabled for a series, it is also deleting outside of the library in which the series records to. This deletes my previous seasons. I would expect this delete after watched feature to only target the library in which the recording is set to. Can this be corrected?
Version 1.14.0.5470
I’m having the same issue. I have 2 separate libraries on separate drives a “Recorded TV” and “TV”. Shows recorded are also deleting similarly named shows on my TV library. I had a recording set for Magnum, P.I. and it was deleting episodes from Magnum P.I. (aka 2018) on my TV library which is a separate show.
