[BUG] Plex not scraping multiple episode files unless they are .mkv
I have my tv show files named correctly show.S01E01-E02.Title. Plex will only recognize E01 if the file is a .m4v or .mp4. It will recognize E01 and E01 if the file is .mkv (I believe it works with .avi as well but did not test it out). I think this is a bug as I cannot think of a reason the container would stop plex from recognizing the second episode.
It appears to be working fine for me.  In the Screenshot below you can see it with episode 7 and 8 in an MP4.  But I also retested files I had that are AVI, MKV, and M4V.
![post-182619-0-20115600-1433688619.jpg|637x500](upload://5IfN9cywOvPqrVgbtyZDmu1vuPS.jpg)
Do you have logs from when you attempted to add the show?  Did you rename the file after it was scanned in?
Tried multiple times. Here is what the Log is showing with .m4v files. I remuxed the files in .mkv and it found them perfectly, but I would prefer to keep them in their original format if possible. This is the pertaining section of the Plex Media Scanner.log. Is there any pertinent information in any of the other logs? Plex is still only scraping the first episode of the file (ex: season 2 e1, 3, 5, 7, 9, 11, etc.)
[spoiler]
Jun 07, 2015 13:29:21:700 [3784] INFO - Windows version: 6.3 (Build 9600)
Jun 07, 2015 13:29:21:700 [3784] INFO - 8 3400 MHz processor(s): Architecture=0, Level=6, Revision=15363
Jun 07, 2015 13:29:21:700 [3784] INFO - PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 60 Stepping 3, GenuineIntel
Jun 07, 2015 13:29:21:700 [3784] DEBUG - “C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe” --scan --refresh --section 2
Jun 07, 2015 13:29:21:700 [3784] DEBUG - Opening 20 database sessions to library, SQLite 3.8.9, threadsafe=1
Jun 07, 2015 13:29:21:778 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/cullTimeline?librarySectionID=2&sinceTime=1433704161
Jun 07, 2015 13:29:21:794 [3784] DEBUG - Scanning TV Shows using en(Plex Series Scanner) with 13379 current media items in the database…
Jun 07, 2015 13:29:21:825 [3784] DEBUG - Performing a scan with ‘Plex Series Scanner’ (language: en virtual: 0).
Jun 07, 2015 13:29:21:825 [3784] DEBUG -   * Scanning D:\Videos\TV Shows
Jun 07, 2015 13:29:21:825 [3784] DEBUG -     * Scanning directory D:\Videos\TV Shows (parent: no)
Jun 07, 2015 13:29:21:825 [3784] DEBUG - Adding subdirectory for scanner: D:\Videos\TV Shows\Doug (1991)
Jun 07, 2015 13:29:21:841 [3784] DEBUG - Skipping over directory ‘’, as nothing as changed; removing 0 media items from map.
Jun 07, 2015 13:29:21:841 [3784] DEBUG -     * Scanning directory D:\Videos\TV Shows\Doug (1991) (parent: yes)
Jun 07, 2015 13:29:21:904 [3784] DEBUG - Adding subdirectory for scanner: D:\Videos\TV Shows\Doug (1991)\Season 1
Jun 07, 2015 13:29:21:904 [3784] DEBUG - Adding subdirectory for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2
Jun 07, 2015 13:29:21:904 [3784] DEBUG - Adding subdirectory for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3
Jun 07, 2015 13:29:21:904 [3784] DEBUG - Adding subdirectory for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4
Jun 07, 2015 13:29:21:904 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Thumbs.db
Jun 07, 2015 13:29:21:904 [3784] DEBUG -     * Scanning directory D:\Videos\TV Shows\Doug (1991)\Season 4 (parent: yes)
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E01-E02.Doug’s Math Problem + Doug’s Big Feat.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E03-E04.Doug’s Bum Rap + Doug & Patti Sittin’ in a Tree.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E05-E06.Doug Door to Door + Doug Tips The Scale.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E07-E08.Doug En Vogue + Doug’s Mail Order Mania.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E09-E10.Doug’s Birthday Present + Doug’s Fan Club.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E11-E12.Doug Runs + Doug Clobbers Patti.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E13-E14.Doug’s Treasure Hunt + Doug’s Brainy Buddy.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E15-E16.Doug Ripped Off! + Doug’s Babysitter.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E17-E18.Doug’s in the Money + Doug’s Sister Act.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E19-E20.Doug Throws a Party + Doug Way Out West.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E21-E22.Doug Graduates + Doug’s Bad Trip.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E23.Doug’s Halloween Adventure.m4v
Jun 07, 2015 13:29:21:997 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E24.Doug’s Christmas Story.m4v
Jun 07, 2015 13:29:22:044 [3784] DEBUG -       * Scanning Doug Season 4 Episode 1
Jun 07, 2015 13:29:22:044 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E01-E02.Doug’s Math Problem + Doug’s Big Feat.m4v]
Jun 07, 2015 13:29:22:044 [3784] DEBUG - Skipping hash check, no size match for 297121678 bytes.
Jun 07, 2015 13:29:22:044 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:22:044 [3784] DEBUG - Creating show ‘Doug’
Jun 07, 2015 13:29:22:044 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:044 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:107 [3784] DEBUG - Added new metadata item (Doug) with ID 29559
Jun 07, 2015 13:29:22:107 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29559&types=2
Jun 07, 2015 13:29:22:107 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:107 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:107 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:107 [3784] DEBUG - Updating metadata item (save) (Doug) with ID 29559
Jun 07, 2015 13:29:22:107 [3784] DEBUG - Creating season 4 for show ‘Doug’
Jun 07, 2015 13:29:22:122 [3784] DEBUG - Added new metadata item () with ID 29560
Jun 07, 2015 13:29:22:122 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29560&types=3
Jun 07, 2015 13:29:22:138 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:138 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:138 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:138 [3784] DEBUG - Added new metadata item (Doug’s Math Problem / Doug’s Big Feat) with ID 29561
Jun 07, 2015 13:29:22:138 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29561&types=4
Jun 07, 2015 13:29:22:138 [3784] DEBUG - Added new media item with ID=39449 (episode=1&episodic=1&name=Doug’s%20Math%20Problem%20%2F%20Doug’s%20Big%20Feat&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:22:138 [3784] DEBUG - Added new media part with ID=39518 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E01-E02.Doug’s Math Problem + Doug’s Big Feat.m4v]
Jun 07, 2015 13:29:22:185 [3784] DEBUG -       * Scanning Doug Season 4 Episode 3
Jun 07, 2015 13:29:22:185 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E03-E04.Doug’s Bum Rap + Doug & Patti Sittin’ in a Tree.m4v]
Jun 07, 2015 13:29:22:185 [3784] DEBUG - Skipping hash check, no size match for 302392532 bytes.
Jun 07, 2015 13:29:22:185 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:22:185 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:22:185 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:185 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:185 [3784] DEBUG - Added new metadata item (Doug’s Bum Rap / Doug & Patti Sittin’ In a Tree) with ID 29562
Jun 07, 2015 13:29:22:185 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29562&types=4
Jun 07, 2015 13:29:22:185 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:185 [3784] DEBUG - Added new media item with ID=39450 (episode=3&episodic=1&name=Doug’s%20Bum%20Rap%20%2F%20Doug%20%26%20Patti%20Sittin’%20In%20a%20Tree&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:22:200 [3784] DEBUG - Added new media part with ID=39519 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E03-E04.Doug’s Bum Rap + Doug & Patti Sittin’ in a Tree.m4v]
Jun 07, 2015 13:29:22:263 [3784] DEBUG -       * Scanning Doug Season 4 Episode 5
Jun 07, 2015 13:29:22:263 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E05-E06.Doug Door to Door + Doug Tips The Scale.m4v]
Jun 07, 2015 13:29:22:263 [3784] DEBUG - Skipping hash check, no size match for 292339009 bytes.
Jun 07, 2015 13:29:22:263 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:22:263 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:22:263 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:263 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:263 [3784] DEBUG - Added new metadata item (Doug Door to Door / Doug Tips the Scale) with ID 29563
Jun 07, 2015 13:29:22:263 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29563&types=4
Jun 07, 2015 13:29:22:263 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:263 [3784] DEBUG - Added new media item with ID=39451 (episode=5&episodic=1&name=Doug%20Door%20to%20Door%20%2F%20Doug%20Tips%20the%20Scale&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:22:263 [3784] DEBUG - Added new media part with ID=39520 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E05-E06.Doug Door to Door + Doug Tips The Scale.m4v]
Jun 07, 2015 13:29:22:294 [3784] DEBUG -       * Scanning Doug Season 4 Episode 7
Jun 07, 2015 13:29:22:294 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E07-E08.Doug En Vogue + Doug’s Mail Order Mania.m4v]
Jun 07, 2015 13:29:22:294 [3784] DEBUG - Skipping hash check, no size match for 282646459 bytes.
Jun 07, 2015 13:29:22:294 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:22:294 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:22:294 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:294 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:294 [3784] DEBUG - Added new metadata item (Doug en Vogue / Doug’s Mail Order Mania) with ID 29564
Jun 07, 2015 13:29:22:294 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29564&types=4
Jun 07, 2015 13:29:22:294 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:310 [3784] DEBUG - Added new media item with ID=39452 (episode=7&episodic=1&name=Doug%20en%20Vogue%20%2F%20Doug’s%20Mail%20Order%20Mania&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:22:310 [3784] DEBUG - Added new media part with ID=39521 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E07-E08.Doug En Vogue + Doug’s Mail Order Mania.m4v]
Jun 07, 2015 13:29:22:357 [3784] DEBUG -       * Scanning Doug Season 4 Episode 9
Jun 07, 2015 13:29:22:357 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E09-E10.Doug’s Birthday Present + Doug’s Fan Club.m4v]
Jun 07, 2015 13:29:22:357 [3784] DEBUG - Skipping hash check, no size match for 292804728 bytes.
Jun 07, 2015 13:29:22:357 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:22:357 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:22:357 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:357 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:357 [3784] DEBUG - Added new metadata item (Doug’s Birthday Present / Doug’s Fan Club) with ID 29565
Jun 07, 2015 13:29:22:357 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29565&types=4
Jun 07, 2015 13:29:22:357 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:357 [3784] DEBUG - Added new media item with ID=39453 (episode=9&episodic=1&name=Doug’s%20Birthday%20Present%20%2F%20Doug’s%20Fan%20Club&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:22:357 [3784] DEBUG - Added new media part with ID=39522 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E09-E10.Doug’s Birthday Present + Doug’s Fan Club.m4v]
Jun 07, 2015 13:29:22:372 [3784] DEBUG -       * Scanning Doug Season 4 Episode 11
Jun 07, 2015 13:29:22:372 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E11-E12.Doug Runs + Doug Clobbers Patti.m4v]
Jun 07, 2015 13:29:22:372 [3784] DEBUG - Skipping hash check, no size match for 295877247 bytes.
Jun 07, 2015 13:29:22:372 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:22:372 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:22:372 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:372 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:372 [3784] DEBUG - Added new metadata item (Doug Runs / Doug Clobbers Patti) with ID 29566
Jun 07, 2015 13:29:22:372 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29566&types=4
Jun 07, 2015 13:29:22:372 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:372 [3784] DEBUG - Added new media item with ID=39454 (episode=11&episodic=1&name=Doug%20Runs%20%2F%20Doug%20Clobbers%20Patti&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:22:372 [3784] DEBUG - Added new media part with ID=39523 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E11-E12.Doug Runs + Doug Clobbers Patti.m4v]
Jun 07, 2015 13:29:22:404 [3784] DEBUG -       * Scanning Doug Season 4 Episode 13
Jun 07, 2015 13:29:22:404 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E13-E14.Doug’s Treasure Hunt + Doug’s Brainy Buddy.m4v]
Jun 07, 2015 13:29:22:404 [3784] DEBUG - Skipping hash check, no size match for 278312810 bytes.
Jun 07, 2015 13:29:22:404 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:22:419 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:22:419 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:419 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:419 [3784] DEBUG - Added new metadata item (Doug’s Treasure Hunt / Doug’s Brainy Buddy) with ID 29567
Jun 07, 2015 13:29:22:419 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29567&types=4
Jun 07, 2015 13:29:22:419 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:419 [3784] DEBUG - Added new media item with ID=39455 (episode=13&episodic=1&name=Doug’s%20Treasure%20Hunt%20%2F%20Doug’s%20Brainy%20Buddy&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:22:419 [3784] DEBUG - Added new media part with ID=39524 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E13-E14.Doug’s Treasure Hunt + Doug’s Brainy Buddy.m4v]
Jun 07, 2015 13:29:22:450 [3784] DEBUG -       * Scanning Doug Season 4 Episode 15
Jun 07, 2015 13:29:22:450 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E15-E16.Doug Ripped Off! + Doug’s Babysitter.m4v]
Jun 07, 2015 13:29:22:450 [3784] DEBUG - Skipping hash check, no size match for 302589496 bytes.
Jun 07, 2015 13:29:22:450 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:22:450 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:22:450 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:450 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:450 [3784] DEBUG - Added new metadata item (Doug Ripped Off / Doug’s Babysitter) with ID 29568
Jun 07, 2015 13:29:22:450 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29568&types=4
Jun 07, 2015 13:29:22:450 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:450 [3784] DEBUG - Added new media item with ID=39456 (episode=15&episodic=1&name=Doug%20Ripped%20Off%20%2F%20Doug’s%20Babysitter&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:22:450 [3784] DEBUG - Added new media part with ID=39525 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E15-E16.Doug Ripped Off! + Doug’s Babysitter.m4v]
Jun 07, 2015 13:29:22:857 [3784] DEBUG -       * Scanning Doug Season 4 Episode 17
Jun 07, 2015 13:29:22:857 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E17-E18.Doug’s in the Money + Doug’s Sister Act.m4v]
Jun 07, 2015 13:29:22:857 [3784] DEBUG - Skipping hash check, no size match for 293638428 bytes.
Jun 07, 2015 13:29:22:857 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:22:857 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:22:857 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:857 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:872 [3784] DEBUG - Added new metadata item (Doug’s In the Money / Doug’s Sister Act) with ID 29569
Jun 07, 2015 13:29:22:872 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29569&types=4
Jun 07, 2015 13:29:22:872 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:872 [3784] DEBUG - Added new media item with ID=39457 (episode=17&episodic=1&name=Doug’s%20In%20the%20Money%20%2F%20Doug’s%20Sister%20Act&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:22:872 [3784] DEBUG - Added new media part with ID=39526 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E17-E18.Doug’s in the Money + Doug’s Sister Act.m4v]
Jun 07, 2015 13:29:22:951 [3784] DEBUG -       * Scanning Doug Season 4 Episode 19
Jun 07, 2015 13:29:22:951 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E19-E20.Doug Throws a Party + Doug Way Out West.m4v]
Jun 07, 2015 13:29:22:951 [3784] DEBUG - Skipping hash check, no size match for 289252158 bytes.
Jun 07, 2015 13:29:22:951 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:22:951 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:22:951 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:951 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:22:951 [3784] DEBUG - Added new metadata item (Doug Throws a Party / Doug Way Out West) with ID 29570
Jun 07, 2015 13:29:22:951 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29570&types=4
Jun 07, 2015 13:29:22:951 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:22:951 [3784] DEBUG - Added new media item with ID=39458 (episode=19&episodic=1&name=Doug%20Throws%20a%20Party%20%2F%20Doug%20Way%20Out%20West&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:22:966 [3784] DEBUG - Added new media part with ID=39527 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E19-E20.Doug Throws a Party + Doug Way Out West.m4v]
Jun 07, 2015 13:29:23:013 [3784] DEBUG -       * Scanning Doug Season 4 Episode 21
Jun 07, 2015 13:29:23:013 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E21-E22.Doug Graduates + Doug’s Bad Trip.m4v]
Jun 07, 2015 13:29:23:013 [3784] DEBUG - Skipping hash check, no size match for 287200683 bytes.
Jun 07, 2015 13:29:23:013 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:013 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:013 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:013 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:013 [3784] DEBUG - Added new metadata item (Doug Graduates / Doug’s Bad Trip) with ID 29571
Jun 07, 2015 13:29:23:013 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29571&types=4
Jun 07, 2015 13:29:23:013 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:013 [3784] DEBUG - Added new media item with ID=39459 (episode=21&episodic=1&name=Doug%20Graduates%20%2F%20Doug’s%20Bad%20Trip&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:23:013 [3784] DEBUG - Added new media part with ID=39528 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E21-E22.Doug Graduates + Doug’s Bad Trip.m4v]
Jun 07, 2015 13:29:23:060 [3784] DEBUG -       * Scanning Doug Season 4 Episode 23
Jun 07, 2015 13:29:23:060 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E23.Doug’s Halloween Adventure.m4v]
Jun 07, 2015 13:29:23:060 [3784] DEBUG - Skipping hash check, no size match for 279712568 bytes.
Jun 07, 2015 13:29:23:060 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:060 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:060 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:060 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:060 [3784] DEBUG - Added new metadata item (Doug’s Halloween Adventure) with ID 29572
Jun 07, 2015 13:29:23:060 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29572&types=4
Jun 07, 2015 13:29:23:075 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:075 [3784] DEBUG - Added new media item with ID=39460 (episode=23&episodic=1&name=Doug’s%20Halloween%20Adventure&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:23:075 [3784] DEBUG - Added new media part with ID=39529 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E23.Doug’s Halloween Adventure.m4v]
Jun 07, 2015 13:29:23:091 [3784] DEBUG -       * Scanning Doug Season 4 Episode 24
Jun 07, 2015 13:29:23:091 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E24.Doug’s Christmas Story.m4v]
Jun 07, 2015 13:29:23:091 [3784] DEBUG - Skipping hash check, no size match for 283633237 bytes.
Jun 07, 2015 13:29:23:091 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:091 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:091 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:091 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:091 [3784] DEBUG - Added new metadata item (Doug’s Christmas Story) with ID 29573
Jun 07, 2015 13:29:23:091 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29573&types=4
Jun 07, 2015 13:29:23:107 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:107 [3784] DEBUG - Added new media item with ID=39461 (episode=24&episodic=1&name=Doug’s%20Christmas%20Story&season=4&show=Doug&year=1991)
Jun 07, 2015 13:29:23:107 [3784] DEBUG - Added new media part with ID=39530 [D:\Videos\TV Shows\Doug (1991)\Season 4\Doug.S04E24.Doug’s Christmas Story.m4v]
Jun 07, 2015 13:29:23:138 [3784] DEBUG -     * Scanning directory D:\Videos\TV Shows\Doug (1991)\Season 3 (parent: yes)
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E01-E02.Doug’s Fat Cat + Doug and Patti P.I…m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E03-E04.Doug’s Servitude + Doug Rocks the House.m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E05-E06.Doug’s Comic Collaboration + Doug’s Pet Capades.m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E07-E08.Doug’s Career Anxiety + Doug’s Big Brawl.m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E09-E10.Doug’s Huge Zit + Doug Flies A Kite.m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E11-E12.Doug and the Weird Kids + Doug’s Behind The Wheel.m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E13-E14.Doug’s New Teacher + Doug On First.m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E15-E16.Doug’s Cartoon + Doug’s Monster Movie.m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E17-E18.Doug’s Hot Property + Doug & The Little Liar.m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E19-E20.Doug Inc. + Doug’s Nightmare on Jumbo St…m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E21-E22.Doug’s Shock Therapy + Doug Is Hamburger Boy.m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E23-E24.Doug and the Yard of Doom + Doug’s Garage Band.m4v
Jun 07, 2015 13:29:23:169 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E25-E26.Doug’s Great Beet War + Doug’s Magic Act.m4v
Jun 07, 2015 13:29:23:216 [3784] DEBUG -       * Scanning Doug Season 3 Episode 1
Jun 07, 2015 13:29:23:216 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E01-E02.Doug’s Fat Cat + Doug and Patti P.I…m4v]
Jun 07, 2015 13:29:23:216 [3784] DEBUG - Skipping hash check, no size match for 279489787 bytes.
Jun 07, 2015 13:29:23:216 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:216 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:216 [3784] DEBUG - Creating season 3 for show 'Doug’
Jun 07, 2015 13:29:23:216 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:216 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:216 [3784] DEBUG - Added new metadata item () with ID 29574
Jun 07, 2015 13:29:23:216 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29574&types=3
Jun 07, 2015 13:29:23:232 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:232 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:232 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:247 [3784] DEBUG - Added new metadata item (Doug’s Fat Cat / Doug and Patti P.I.) with ID 29575
Jun 07, 2015 13:29:23:247 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29575&types=4
Jun 07, 2015 13:29:23:247 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:247 [3784] DEBUG - Added new media item with ID=39462 (episode=1&episodic=1&name=Doug’s%20Fat%20Cat%20%2F%20Doug%20and%20Patti%20P%2EI%2E&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:247 [3784] DEBUG - Added new media part with ID=39531 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E01-E02.Doug’s Fat Cat + Doug and Patti P.I…m4v]
Jun 07, 2015 13:29:23:326 [3784] DEBUG -       * Scanning Doug Season 3 Episode 3
Jun 07, 2015 13:29:23:326 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E03-E04.Doug’s Servitude + Doug Rocks the House.m4v]
Jun 07, 2015 13:29:23:326 [3784] DEBUG - Skipping hash check, no size match for 299117518 bytes.
Jun 07, 2015 13:29:23:326 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:326 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:326 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:326 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:326 [3784] DEBUG - Added new metadata item (Doug’s Servitude / Doug Rocks the House) with ID 29576
Jun 07, 2015 13:29:23:326 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29576&types=4
Jun 07, 2015 13:29:23:341 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:341 [3784] DEBUG - Added new media item with ID=39463 (episode=3&episodic=1&name=Doug’s%20Servitude%20%2F%20Doug%20Rocks%20the%20House&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:341 [3784] DEBUG - Added new media part with ID=39532 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E03-E04.Doug’s Servitude + Doug Rocks the House.m4v]
Jun 07, 2015 13:29:23:482 [3784] DEBUG -       * Scanning Doug Season 3 Episode 5
Jun 07, 2015 13:29:23:482 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E05-E06.Doug’s Comic Collaboration + Doug’s Pet Capades.m4v]
Jun 07, 2015 13:29:23:482 [3784] DEBUG - Skipping hash check, no size match for 290255122 bytes.
Jun 07, 2015 13:29:23:482 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:482 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:482 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:482 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:482 [3784] DEBUG - Added new metadata item (Doug’s Comic Collaboration / Doug’s Pet Capades) with ID 29577
Jun 07, 2015 13:29:23:482 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29577&types=4
Jun 07, 2015 13:29:23:482 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:482 [3784] DEBUG - Added new media item with ID=39464 (episode=5&episodic=1&name=Doug’s%20Comic%20Collaboration%20%2F%20Doug’s%20Pet%20Capades&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:482 [3784] DEBUG - Added new media part with ID=39533 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E05-E06.Doug’s Comic Collaboration + Doug’s Pet Capades.m4v]
Jun 07, 2015 13:29:23:560 [3784] DEBUG -       * Scanning Doug Season 3 Episode 7
Jun 07, 2015 13:29:23:560 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E07-E08.Doug’s Career Anxiety + Doug’s Big Brawl.m4v]
Jun 07, 2015 13:29:23:560 [3784] DEBUG - Skipping hash check, no size match for 299890241 bytes.
Jun 07, 2015 13:29:23:560 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:560 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:560 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:560 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:560 [3784] DEBUG - Added new metadata item (Doug’s Career Anxiety / Doug’s Big Brawl) with ID 29578
Jun 07, 2015 13:29:23:560 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29578&types=4
Jun 07, 2015 13:29:23:560 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:560 [3784] DEBUG - Added new media item with ID=39465 (episode=7&episodic=1&name=Doug’s%20Career%20Anxiety%20%2F%20Doug’s%20Big%20Brawl&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:560 [3784] DEBUG - Added new media part with ID=39534 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E07-E08.Doug’s Career Anxiety + Doug’s Big Brawl.m4v]
Jun 07, 2015 13:29:23:638 [3784] DEBUG -       * Scanning Doug Season 3 Episode 9
Jun 07, 2015 13:29:23:638 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E09-E10.Doug’s Huge Zit + Doug Flies A Kite.m4v]
Jun 07, 2015 13:29:23:638 [3784] DEBUG - Skipping hash check, no size match for 288284948 bytes.
Jun 07, 2015 13:29:23:638 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:638 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:638 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:638 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:638 [3784] DEBUG - Added new metadata item (Doug’s Huge Zit / Doug Flies a Kite) with ID 29579
Jun 07, 2015 13:29:23:638 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29579&types=4
Jun 07, 2015 13:29:23:654 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:654 [3784] DEBUG - Added new media item with ID=39466 (episode=9&episodic=1&name=Doug’s%20Huge%20Zit%20%2F%20Doug%20Flies%20a%20Kite&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:654 [3784] DEBUG - Added new media part with ID=39535 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E09-E10.Doug’s Huge Zit + Doug Flies A Kite.m4v]
Jun 07, 2015 13:29:23:732 [3784] DEBUG -       * Scanning Doug Season 3 Episode 11
Jun 07, 2015 13:29:23:732 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E11-E12.Doug and the Weird Kids + Doug’s Behind The Wheel.m4v]
Jun 07, 2015 13:29:23:732 [3784] DEBUG - Skipping hash check, no size match for 298192297 bytes.
Jun 07, 2015 13:29:23:732 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:732 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:732 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:732 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:732 [3784] DEBUG - Added new metadata item (Doug and the Weird Kids / Doug’s Behind the Wheel) with ID 29580
Jun 07, 2015 13:29:23:732 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29580&types=4
Jun 07, 2015 13:29:23:747 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:747 [3784] DEBUG - Added new media item with ID=39467 (episode=11&episodic=1&name=Doug%20and%20the%20Weird%20Kids%20%2F%20Doug’s%20Behind%20the%20Wheel&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:747 [3784] DEBUG - Added new media part with ID=39536 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E11-E12.Doug and the Weird Kids + Doug’s Behind The Wheel.m4v]
Jun 07, 2015 13:29:23:826 [3784] DEBUG -       * Scanning Doug Season 3 Episode 13
Jun 07, 2015 13:29:23:826 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E13-E14.Doug’s New Teacher + Doug On First.m4v]
Jun 07, 2015 13:29:23:826 [3784] DEBUG - Skipping hash check, no size match for 290623072 bytes.
Jun 07, 2015 13:29:23:826 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:826 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:826 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:826 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:826 [3784] DEBUG - Added new metadata item (Doug’s New Teacher / Doug On First) with ID 29581
Jun 07, 2015 13:29:23:826 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29581&types=4
Jun 07, 2015 13:29:23:826 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:826 [3784] DEBUG - Added new media item with ID=39468 (episode=13&episodic=1&name=Doug’s%20New%20Teacher%20%2F%20Doug%20On%20First&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:826 [3784] DEBUG - Added new media part with ID=39537 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E13-E14.Doug’s New Teacher + Doug On First.m4v]
Jun 07, 2015 13:29:23:872 [3784] DEBUG -       * Scanning Doug Season 3 Episode 15
Jun 07, 2015 13:29:23:872 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E15-E16.Doug’s Cartoon + Doug’s Monster Movie.m4v]
Jun 07, 2015 13:29:23:872 [3784] DEBUG - Skipping hash check, no size match for 291720075 bytes.
Jun 07, 2015 13:29:23:872 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:872 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:872 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:872 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:872 [3784] DEBUG - Added new metadata item (Doug’s Cartoon / Doug’s Monster Movie) with ID 29582
Jun 07, 2015 13:29:23:872 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29582&types=4
Jun 07, 2015 13:29:23:872 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:872 [3784] DEBUG - Added new media item with ID=39469 (episode=15&episodic=1&name=Doug’s%20Cartoon%20%2F%20Doug’s%20Monster%20Movie&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:872 [3784] DEBUG - Added new media part with ID=39538 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E15-E16.Doug’s Cartoon + Doug’s Monster Movie.m4v]
Jun 07, 2015 13:29:23:904 [3784] DEBUG -       * Scanning Doug Season 3 Episode 17
Jun 07, 2015 13:29:23:904 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E17-E18.Doug’s Hot Property + Doug & The Little Liar.m4v]
Jun 07, 2015 13:29:23:919 [3784] DEBUG - Skipping hash check, no size match for 288218919 bytes.
Jun 07, 2015 13:29:23:919 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:919 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:919 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:919 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:919 [3784] DEBUG - Added new metadata item (Doug’s Hot Property / Doug & the Little Liar) with ID 29583
Jun 07, 2015 13:29:23:919 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29583&types=4
Jun 07, 2015 13:29:23:919 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:919 [3784] DEBUG - Added new media item with ID=39470 (episode=17&episodic=1&name=Doug’s%20Hot%20Property%20%2F%20Doug%20%26%20the%20Little%20Liar&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:919 [3784] DEBUG - Added new media part with ID=39539 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E17-E18.Doug’s Hot Property + Doug & The Little Liar.m4v]
Jun 07, 2015 13:29:23:951 [3784] DEBUG -       * Scanning Doug Season 3 Episode 19
Jun 07, 2015 13:29:23:951 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E19-E20.Doug Inc. + Doug’s Nightmare on Jumbo St…m4v]
Jun 07, 2015 13:29:23:951 [3784] DEBUG - Skipping hash check, no size match for 291981552 bytes.
Jun 07, 2015 13:29:23:951 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:951 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:951 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:951 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:951 [3784] DEBUG - Added new metadata item (Doug Inc. / Doug’s Nightmare On Jumbo Street) with ID 29584
Jun 07, 2015 13:29:23:951 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29584&types=4
Jun 07, 2015 13:29:23:951 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:951 [3784] DEBUG - Added new media item with ID=39471 (episode=19&episodic=1&name=Doug%20Inc%2E%20%2F%20Doug’s%20Nightmare%20On%20Jumbo%20Street&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:951 [3784] DEBUG - Added new media part with ID=39540 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E19-E20.Doug Inc. + Doug’s Nightmare on Jumbo St…m4v]
Jun 07, 2015 13:29:23:997 [3784] DEBUG -       * Scanning Doug Season 3 Episode 21
Jun 07, 2015 13:29:23:997 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E21-E22.Doug’s Shock Therapy + Doug Is Hamburger Boy.m4v]
Jun 07, 2015 13:29:23:997 [3784] DEBUG - Skipping hash check, no size match for 296168439 bytes.
Jun 07, 2015 13:29:23:997 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:23:997 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:23:997 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:997 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:23:997 [3784] DEBUG - Added new metadata item (Doug’s Shock Therapy / Doug Is Hamburger Boy) with ID 29585
Jun 07, 2015 13:29:23:997 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29585&types=4
Jun 07, 2015 13:29:23:997 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:23:997 [3784] DEBUG - Added new media item with ID=39472 (episode=21&episodic=1&name=Doug’s%20Shock%20Therapy%20%2F%20Doug%20Is%20Hamburger%20Boy&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:23:997 [3784] DEBUG - Added new media part with ID=39541 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E21-E22.Doug’s Shock Therapy + Doug Is Hamburger Boy.m4v]
Jun 07, 2015 13:29:24:029 [3784] DEBUG -       * Scanning Doug Season 3 Episode 23
Jun 07, 2015 13:29:24:029 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E23-E24.Doug and the Yard of Doom + Doug’s Garage Band.m4v]
Jun 07, 2015 13:29:24:029 [3784] DEBUG - Skipping hash check, no size match for 291349650 bytes.
Jun 07, 2015 13:29:24:029 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:24:029 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:24:029 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:24:029 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:24:044 [3784] DEBUG - Added new metadata item (Doug and the Yard of Doom / Doug’s Garage Band) with ID 29586
Jun 07, 2015 13:29:24:044 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29586&types=4
Jun 07, 2015 13:29:24:044 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:24:044 [3784] DEBUG - Added new media item with ID=39473 (episode=23&episodic=1&name=Doug%20and%20the%20Yard%20of%20Doom%20%2F%20Doug’s%20Garage%20Band&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:24:044 [3784] DEBUG - Added new media part with ID=39542 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E23-E24.Doug and the Yard of Doom + Doug’s Garage Band.m4v]
Jun 07, 2015 13:29:24:076 [3784] DEBUG -       * Scanning Doug Season 3 Episode 25
Jun 07, 2015 13:29:24:076 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E25-E26.Doug’s Great Beet War + Doug’s Magic Act.m4v]
Jun 07, 2015 13:29:24:076 [3784] DEBUG - Skipping hash check, no size match for 301799022 bytes.
Jun 07, 2015 13:29:24:076 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:24:076 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:24:076 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:24:076 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:24:076 [3784] DEBUG - Added new metadata item (Doug Operation Moody School / Doug’s Magic Act) with ID 29587
Jun 07, 2015 13:29:24:076 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29587&types=4
Jun 07, 2015 13:29:24:076 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:24:076 [3784] DEBUG - Added new media item with ID=39474 (episode=25&episodic=1&name=Doug%20Operation%20Moody%20School%20%2F%20Doug’s%20Magic%20Act&season=3&show=Doug&year=1991)
Jun 07, 2015 13:29:24:076 [3784] DEBUG - Added new media part with ID=39543 [D:\Videos\TV Shows\Doug (1991)\Season 3\Doug.S03E25-E26.Doug’s Great Beet War + Doug’s Magic Act.m4v]
Jun 07, 2015 13:29:24:122 [3784] DEBUG -     * Scanning directory D:\Videos\TV Shows\Doug (1991)\Season 2 (parent: yes)
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E01-E02.Doug Takes the Case + Doug’s Secret Song.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E03-E04.Doug’s Got No Gift + Doug VS The Klotzoid Zombies.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E05-E06.Doug’s Secret Admirer + Doug’s On TV.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E07-E08.Doug’s Dinner Date + Doug Meets Fentruck.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E09-E10.Doug’s On Stage + Doug’s Worst Nightmare.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E11-E12.Doug’s Derby Dilemma + Doug’s On His Own.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E13-E14.Doug Meets The Rulemeister + Doug’s a Genius.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E15-E16.Doug Saves Roger + Doug’s Big News.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E17-E18.Doug’s a Big Fat Liar + Doug Wears Tights.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E19-E20.Doug On The Trail + Doug Meets RoboBone.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E21-E22.Doug Pumps Up + Doug Goes Hollywood.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E23-E24.Doug’s Hot Ticket + Doug’s Dental Disaster.m4v
Jun 07, 2015 13:29:24:154 [3784] DEBUG - Adding file for scanner: D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E25-E26.Doug’s Lost Weekend + Doug’s Lucky Hat.m4v
Jun 07, 2015 13:29:24:201 [3784] DEBUG -       * Scanning Doug Season 2 Episode 1
Jun 07, 2015 13:29:24:201 [3784] DEBUG - Looking for path match for [D:\Videos\TV Shows\Doug (1991)\Season 2\Doug.S02E01-E02.Doug Takes the Case + Doug’s Secret Song.m4v]
Jun 07, 2015 13:29:24:201 [3784] DEBUG - Skipping hash check, no size match for 290699763 bytes.
Jun 07, 2015 13:29:24:201 [3784] DEBUG - No match for hash.
Jun 07, 2015 13:29:24:201 [3784] DEBUG - Found existing show by name 29559
Jun 07, 2015 13:29:24:201 [3784] DEBUG - Creating season 2 for show 'Doug’
Jun 07, 2015 13:29:24:201 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:24:201 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:24:216 [3784] DEBUG - Added new metadata item () with ID 29588
Jun 07, 2015 13:29:24:216 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29588&types=3
Jun 07, 2015 13:29:24:232 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/:/metadata/flushMetadataCounterCache
Jun 07, 2015 13:29:24:232 [3784] DEBUG - Downloading document http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:24:232 [3784] DEBUG - HTTP requesting to: http://127.0.0.1:32400/library/changestamp
Jun 07, 2015 13:29:24:232 [3784] DEBUG - Added new metadata item (Doug Takes the Case / Doug’s Secret Song) with ID 29589
Jun 07, 2015 13:29:24:232 [3784] DEBUG - HTTP requesting to: <a data-ipb=‘nomediaparse’ href='http://127.0.0.1:32400/:/metadata/notify/create?librarySectionID=2&ids=29589&type
By any chance do your files have embedded metadata that is being read?
The reason I ask is that all of your episodes are adding the title's for both episodes:
Jun 07, 2015 13:29:26:482 [3784] DEBUG - Added new metadata item (Doug's Fair Lady / Doug Says Goodbye) with ID 29615
Where if it was only detecting as episode 24 it should be just pulling the Doug's Fair Lady title.
That could be it, can I stop plex from scraping metadata from the episodes or should I manually remove the metadata from each file?
There's two ways I know of doing it.
1) Deselect local media/Set it below thetvdb from the server settings.
2) Manually remove them.  For MP4's I use a tool called Mp3 tag to load them all up and clear all the tags at once.  If it's only one or two then I normally just do it through the file details.
I am also not 100% sure this is your problem.  Looking at my current scan after readding my Doug show I do see a separate scan for each episode (even with episodes that share the same file)
The next question would be if these files were named properly before they were scanned or if you corrected it after a scan?  Occasionally, Plex will have trouble picking up changes and requires a small set of steps to correct:  Temporarily move the show to a new folder, rescan the library, empty trash, move the show back, and rescan the library.  This basically removes the entries for the show from the database and gives the server a fresh rescan of the files.
I named them correctly before the scan. Also, before remuxing to mkv to see if the problem was fixed, I made sure to delete the files, rescan, clean bundles, and empty trash to be sure that there was a new scan each time. Ill try to remove the metadata when I get back from work. Thanks for the help.
I’m having the same problem… Any luck?
Yes, When I ripped the videos, I ripped the metadata with it. So plex was scraping the metadata stored in the files. I downloaded a program called mp3tag and removed all the metadata stored in the files so that plex could create a fresh metadata from tvdb.
I gave that a shot and still no luck… My issue is with the show Doug. I removed the folder from the library, emptied the trash and cleaned the bundles. I then cleared out the metadata from the files and added the folder back into the library. For some reason it’s only showing 13 episodes instead of 25 (episode 1 is its own file, the rest are two episodes per file). It’s strange because I have another show (Rocko’s Modern Life) that is named with the exact same format and Plex understands there are 2 shows in each file… Any ideas?
