Testing the latest (and older) server builds (on docker) using Android TV Plex app. The video never starts if burn-in is set to automatic or only for advanced formats. Just shows the orange circle for a very long time.
How to verify and work around the issue:
So, if you have multiple versions of the same media (movie or series). Doesn’t matter what resolution they are. Transcoding will fail and the media never plays if subtitles are enabled. Ensuring there is only 1 version of the media (emptying trash), restarting the app and transcoding with subtitles enabled works.
This is definitely a bug in the Android App as this works just fine ChromeCasting to the same CCWGTV device or using Web Player.
Did this on 5-6 movies that never started when transcoding with subtitles and they all work now.
Server Version#1.40.5.8829:
Player Version#10.19.2.1192 (74c193cc)
Plex Media Server Logs_2024-08-09_17-29-34.zip (14.2 KB)
Ref: Plex transcoding bug on Android & Android TV - Plex Players - Plex Forum
