BUG - Plexamp / Sonos app volume issue
So I’m not sure if this can be fixed but Fingers crossed it can. I love plexamp and casting to my sonos via iOS and after kicking off something to play when I go to the iOS (iPhone) lock screen the volume “works” however once you set it the volume slider resets to 0, music continues playing normally it just makes it hard to turn it up or down a little because you have no frame of reference to where the volume was at already.
Wanted to add this also happens in windows after hitting play and checking the volume its at zero when its clearly not since I can hear music playing at a decent volume. Looks like the app isn’t checking the volume before the slide appears.
