[Bug Report] PlexAmp on macOS & Android showing incorrect album codec badge values
Server Version#: 1.21.0.3711
Player Version#: 3.4.0
Device: Pixel 3 XL running Android 11
Device: Mid-2015 MacBook Pro 15-inch running macOS Mojave 10.14.6
So, I noticed that the album codec badges are not being shown correctly in the Home section or any section that isn’t the normal playing screen. Like StarCraft as an example. It’s showing up as MP3 442 (example 2) (example 3). But, when in the normal playing section, it correctly shows up as MP3 320. I also confirmed the same issue is also showing up on the Android app.
This looks like a pretty widespread error. Is this an already known issue? Apologies if it is.
Try analyzing the album (in the web app) and see if that fixes it.
That seemed to fix it. Thanks!
