[BUG]Screen Saver activates during playback in some cases
Player Version#: 5.11.1
Steps to reproduce:
  1. Start episode playback
  2. Pause the playback
  3. Press “Play next” or “Play previous” - next/previous episode playback starts
  4. Screen Saver activates after configured time(in Settings) with episode audio in background
Screen Saver timer activated after the initial “Pause” press should be deactivated after new playback is started.
Pressing “Pause” then “Play” will return to normal playback with no Screen Saver interruption.
This bug doesn’t occur if “Play next” or “Play previous” is pressed during playback in progress, occurs only during paused playback.
I was able to reproduce this and filed an issue. Thanks for the report!
