Couple small bugs for Samsung App
Latest version of server and app.
Just a couple small bugs I’ve come across:
  1. When you skip credits, it doesn’t start the countdown timer for the next episode. It just waits for you to press play again.
  2. TV episode was paused long enough for the screensaver to come on. I pressed play while the screensaver was still running. The video resumed fine, but then when it played to the end, the screen was blank while the timer counted down to the next episode. It played the next episode fine, and then again and again until I interrupted it between videos. It seems like the screensaver was still playing in between each episode.
  3. My app recently upgraded automatically and I lost my config in the app. It’s happened a few times before but not every time. Is there anyway to backup/save the settings so I don’t have to re-apply them if it happens again?
Thanks for all your and the teams’s hard work @sLumpy !
I was able to reproduce #2 in a different way: I paused a TV episode long enough for the screensaver to kick in, pressed the play button on the remote to resume and then went to look at the playlist of upcoming episodes…the screensaver took over and I had to click through it again.
