Looks like the “dual displays with different zoom levels” issue has made a return in the new builds of Plex HTPC (1.28.3.3355 as I’m typing this) if “HDR Metadata Passthru (experimental)” is enabled.
With that option enabled, after playback the UI is approximately 125% zoomed in (from the bottom left), causing the top and right to be cutoff. The monitor it is displaying on has a zoom level of 125% in Windows Display setting. The second (main) monitor has a zoom factor of 100%.
This behavior does not occur if “HDR Metadata Passthru” option is not enabled. Logs attached and here is a screenshot:
Plex HTPC.log (809.9 KB)
Thanks!
