[BUGS] Android 8.16.0.24099-beta
Hello,
i’ve just updated to latest Android Player Beta (8.16.0.24099) and noticed, that some of the german translations are missing, e.g. Recently added to “Libary”, in Settings “Friendly name” is not translated either.
In addition, the 4K HDR Icons are missing in Player, in 8.15 latest non-beta, its working, probably related to new ExoPlayer merge?
Another issue is, that the play next screen (post play?) is messed up. Video do not change to a smaller window, it overlaps the whole play next screen. Only works if you let the episode end.
EDIT: Another bug found. Clicking next episode right before the end of a episode ends up in an infinite spinning circle.
And you guys wanna keep the Blur Background on Homescreen? Looks horrible, the grey in Version 8.15 was a lot better. Hope you change it back.
The translations will most probably be added in the next release.
The 4K / HDR icons in the player are tied to the information from the server, can you confirm that the server has detected HDR / 4K resolutions? As they seem to be appearing when testing here.
We’re aware of this issue and working on a fix.
Do you mean the player skip button or on postplay?
Thanks for feedback, there will be some changes around that shortly.
Yeah, same episode is showing 4K HDR in 8.15, in latest beta tv switches to HDR but no icons coming up. And yeah, Server is showing 4K HDR in collection.
When i press the Skip/Next Button in Player it gets stuck in spinning circle, and next episode is shown with 1:01 minute runtime. Same happens in Post Play Screen, when 10 seconds are over i get the infinite spinning too. When i go back to home screen and start the next episode its working.
