Bundle add to Watchlist
Can I mass add to watchlist in a bundle with one click? Like select all and then add to watchlist?
Yes.
  1. Multi-select the items you want to add to the watchlist
  2. Click the bookmark/watchlist icon in the action bar
Ok nice!
That does not seem to work everythwere though?
And could i also add a specific actor or director to the watchlist and everything that that director or actor has done be automatically added to watchlist? Both present and future things?
The watchlist currently only supports movies and series, but not persons.
https://support.plex.tv/articles/universal-watchlist/
Ok, can you add collections too? Like all disney? All iceage? I have added some to the watchlist and only a few under some tab i could mass select all and add to watchlist. The rest i had to manually add to watchlist one by one.
No, at this time this isn’t possible/supported.
Ok, what about automatically add everything that goes on cinematics to watchlist?
No. Though, you can find a hub for upcoming releases and upcoming blockbusters in Plex‘s Discover section.
Yeah ok.
Can my suggestion be put for consideration for future features?
