Button not registering in Plex Media Player
I was previously using RasPlex and have now switched to PMP Embedded on my Rpi2. One thing I noticed that was my remote has a back button and it worked fine on RasPlex, but now on PMP Embedded it no longer works. I figured it was something that just needed to be fixed with an inputmap config. When I follow the instructions (https://support.plex.tv/hc/en-us/articles/216459997-Create-your-own-inputmap) it says to press the button on the remote and look in the plexmediaplayer.log file to see what button was pushed. However, when I press the button I do not see anything logged. If I press other buttons, it logs it as expected. I know the button previously worked, but now does not. I know the remote is sending a command because I can see the LED light up on the remote when I press the button. I am not sure how to proceed since I don’t know the button name nor can I can confirm that the PMP is even registering that a button was pushed at all. The remote is Aerb 2.4Ghz wireless remote.
Any help would be appreciated.
Thanks!
