Hoping a dev will check out the logs here (debugging on).
With the latest update, movies and TV are not readily accessible from Roku, Web, or Mac OS interfaces. Dashboard gone, as are TV or Movie. I can however find and play titles via search. That works fine. So the meta date is there, and when the UI is directed via search, all is good including playback position etc.
Tried optimizing database but that fails. I’d also had automatic scheduled optimization on anyway. This all started with the latest plex release Version 1.0.3.2461. I did try installing an older server version 0.9.17 but that didn’t solve the issue.
Logs attached.
If needed, I’ll delete the library and rebuild it. A lot of custom work will go away. However, if this is a know bug, then I may wait. I’m also worried that I’ll just destroy work I’ve done with my meta data and not solve some other issue. Inquiring minds want to know. Thanks!
