Thanks for mentioning that. I’d not heard of it. Their web site says the right things for me.
If Plex proves to be unusable, I may give it a try.
If you have an advanced router, you should be able to configure it to block certain internal IP’s from accessing the internet. That might solve your concerns.
To protect my IOT’s I use a NAT solution.
Yep I simply said (if I read what you’re saying correctly) that I’m not going to spend the time working on an Android TV that I have on a Windows PC. (Where I’ve made changes to prevent surveillance and “phoning home”.)
Thanks for that. A useful post.
I’m doing that to prevent the Bravia contacting the open Internet while allowing it onto the local LAN.
Thanks guys for the time and effort spent helping me sort this out. Much appreciated.
I don’t currently have a solution but I have tested and eliminated a number of approaches.
I’ll get back to troubleshooting this later.
