I am not routing it specifically, i believe docker is doing it by default
I meant your workstations/players are on 192.x.y.z and your PMS on 172.x.y.z
So if using bridge mode, add an IP to the docker for your PMS in the 192 range, and make that the primary one…
And again, no idea how to, since not a docker person
i did something else. so docker was using ingress to route internally so i used “host” mode of docker instead of “ingress” mode so now the ports are connecting direct to container instead of through the mesh route.
with this i am able to connect through plex on android but on plexamp (which seems weird)
after the last changes, plexamp is the only problem. plex app on android can see local server but not plexamp
