Can we customize Plex Recommendations?
I like what is being done with Recommendations.
In fact I think that it is the single most important feature that will drive people to the product.
Are there any plugins that allow us to extend recommendations?
Not looking for a popularity based learning algorithm.
Just a way to manually make recommendations or a plugin for automatic carousel creations.
Current carousel’s available:
Recently Added
Top Rated
Recently released
Rediscover
More in folder
I know there is automatic category creation, but that only works on web and Collections does not display on the firestick, or android, or Xbox.
Be great if there was a way or something in the works to extend collections to all devices.
How about extend the tags when scraping and create groupings based on the highest quantity of tags that have a highest average IDMB rating.
Does something like that exist ?
Or someone need any help with any plugin projects underway ?
I don’t have a FireStick, PlayStation or Xbox at hand… but from what I’ve seen, adding hubs based on collections to your Home Screen or a library’s Recommended tab should apply to all clients (though you need to use the web app to prepare/manage them)
Publishing Collections! YESSSS!!
OMFG this is the most awesome amazing feature !!!
An awesome way to customize recommendations!
Create a collection >
check to make it visible >
(Settings: Manage: Libraries) Check to add it to recommended.
Can’t believe I didn’t know about this. Exactly what I have been searching for.
Next step.
Auto make collections based on IMDB movie categorizations. :slight_smile:
