Can you stream audio only tv for low bandwidth connections?
Can you create custom low bandwidth Playback Settings for low bandwidth connections?
a feature that I use often with Slingbox is the Audio Only that provides the audio streaming and only uses 50kbps of bandwidth. This is useful for listening to the evening news at remote locations with little cellphone bandwidth.
I just added a HDHomeRun Tuner for Live and DVR streaming to our Plex Windows Server and have not figured out a way to add a “audio only” to the Playback Settings on the Android or IOS Plex clients. the lowest bandwidth setting is the 240p 0.3 mbps setting.
Any suggestions? I’ve done lots of google searches and Plex Forum searches to no avail.
Thanks.
Pat\erver Version#:
