Can't add labels
Hi I am trying to add labels to film and tv sources. In this guide it says there should be a “sharing” tab when i go to edit the source yv show or film https://support.plex.tv/articles/204232573-restricting-the-shares/
However i have no sharing tab. I have all other tabs shown in the screenshot (general, tags, posters and background), but not “sharing”. I have a lifetime pass.
Can anyone help me to understand where i am going wrong please?
Can you provide a screenshot? I can’t think of why it wouldn’t be there for you.
Thanks so much for thq quick reply! I realised it was because I was trying to label individual episodes instead of the entire series.
I’m trying to label series, and the series Edit pop up doesn’t have labels under Sharing any more. Can’t find it on show, on season, or on episode. Used to be on show. Used to be like the last screenshot in this guide:
I still labels in restrictions, and can sort / filter the library by labels, the labels are in the data. But last show I labeled was 4 months ago, can’t find it since then across a few Plex Server updates. Currently using Plex Web Version 4.87.2, server Version 1.30.1.6497.
Hmm. There should be a sharing tab on the left. What version of Plex Web are you using?
Edit: Oops, I see you say 4.87.2. That’s a bit old. Can you try the latest at app.plex.tv.
Usually it’s a browser extension blocking the “Sharing” tab.
The Sharing tab is there on app.plex.tv, which shows me Plex Web Version 4.97.3. Here is the same screenshot (I have both tabs open, 4.97.3 shows Sharing, 4.87.2 does not):
Plex Web Version 4.87.2 is served to me from the server version currently available on your pro user downloads, Plex Server 1.30.1.6497-5fc2e0894, December 14, 2022
I’m glad I can edit this somewhere. I hope you can let the server build team know.
Can you check the full version? I’m seeing the sharing tab on 4.87.2.25887-d04a1ad.
