Can't auto-update
I’ve got Rasplex 0.4.1, when I go to the update screen it shows no update available for any of the release categories, yet I know that 0.6.0 & 0.7.1 are available. Am I missing something here or do I need to re-flash the SD card to upgrade?
Auto update doesn’t work in that version, sorry. You need to reflash your SD card, see here https://github.com/RasPlex/RasPlex/wiki/Install-Rasplex-using-GetRasPlex-for-OSX-or-Windows-GUI
Would suggest waiting a couple of days, 7.2 is due for release with a number of fixes and new functions.
Regards
thanks. Had guessed as much & had ploughed on with re-flashing anyway. Guess should be able to auto-update to 7.2 when it comes out though?
Yes, auto update has worked fine since 0.6
Regards
Any hints what may be new in 0.7.2? Is the stuttering fixed that showed up in 0.7.1 maybe? :smiley:
