Can't claim server with account that has Plex Pass
You are not connected directly to HHO-Main so streaming quality may be limited. You may be able to connect directly to this server by changing your home network settings
it found main now and the libraries are there,
That means it thinks you are on a different network than tha sever for some reason. ( I assume you are actually on that computer though
no idea what happened to studio…
OK. If you are on that computer then the only thing I can see that might be causing weirdness is you appear to have IPv6 enabled in server network settings which I don’t think you need if you are only using it locally.
other devices need v6 and now the old account with lifetime pass has it s libraries agin and seems to work
ok that is good.
:+1: Can you access it with those other local devices now ok as well?
need to sign up the tv
PLEX works now on TV
no idea what you changed on your server side but all seems fine again
ty for your help
regards HHO
