I’m trying to delete the entire recording schedule of a show which airs everyday, but do not see an option to do that.
I click on the episode that is going to be recorded, then I select “Modify Recording”. Then I select “Delete Recording”. This only deletes that particular recording, not all future recordings.
Am I missing something?
That “Delete Recording” may actually be “Cancel Recording”. I am not at the server as I write this.
Thanks for your help.
The option should be cancel recording as you mentioned. If you are cancelling a recording that is a series it should cancel all future recordings of that show. If the recording you are cancelling is a single episode it would only cancel that episode obviously. If you are not seeing this behavior perhaps some screenshots to show what you are seeing at each step of the cancel.
My wife had individually selected episodes to record, rather than the entire series. Once I learned that, it made sense why I could not cancel the series.
