Can't get it to work
Ok. I rebooted the system (turned off my computer).
Holy mother of all gods!!!! It's running!!! No more error message! Or are there others?
12:52:14 PlexConnect: ***
12:52:14 PlexConnect: PlexConnect
12:52:14 PlexConnect: Press CTRL-C to shut down.
12:52:14 PlexConnect: started: 12:52:14
12:52:14 PlexConnect: Version: 0.3.1+
12:52:14 PlexConnect: Python: 2.7.5 (default, Mar  9 2014, 22:15:05)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
12:52:14 PlexConnect: Host OS: darwin
12:52:14 PlexConnect: IP_self: 192.168.1.44
12:52:14 DNSServer: started: 12:52:14
12:52:14 DNSServer: ***
12:52:14 DNSServer: DNSServer: Serving DNS on 192.168.1.44 port 53.
12:52:14 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.44
12:52:14 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
12:52:14 DNSServer: forward other to higher level DNS: 8.8.8.8
12:52:14 WebServer: started: 12:52:14
12:52:14 WebServer: ***
12:52:14 WebServer: WebServer: Serving HTTP on 192.168.1.44 port 80.
12:52:14 WebServer: WebServer: Serving HTTPS on 192.168.1.44 port 443.
12:54:02 DNSServer: DNS request received!
12:54:02 DNSServer: Source: ('192.168.1.126', 62269)
12:54:02 DNSServer: Domain: init.itunes.apple.com
12:54:02 DNSServer: ***forward request
12:54:03 DNSServer: -> DNS response from higher level
12:54:03 DNSServer: DNS request received!
12:54:03 DNSServer: Source: ('192.168.1.126', 62269)
12:54:03 DNSServer: Domain: init.itunes.apple.com
12:54:03 DNSServer: ***forward request
12:54:03 DNSServer: Source: ('192.168.1.126', 49750)
12:54:03 DNSServer: Domain: p40-buy.itunes.apple.com
12:54:04 DNSServer: -> DNS response from higher level
12:54:04 DNSServer: DNS request received!
12:54:04 DNSServer: Source: ('192.168.1.126', 61780)
12:54:04 DNSServer: Domain: xp.apple.com
12:54:04 DNSServer: ***forward request
12:54:04 DNSServer: Source: ('192.168.1.126', 57524)
12:54:04 DNSServer: Domain: EVIntl-ocsp.verisign.com
12:54:08 DNSServer: DNS request received!
12:54:08 DNSServer: Source: ('192.168.1.126', 63495)
12:54:08 DNSServer: Domain: trailers.apple.com
12:54:08 DNSServer: ***intercept request
12:54:08 DNSServer: -> DNS response: 192.168.1.44
12:54:10 DNSServer: DNS request received!
12:54:10 DNSServer: Source: ('192.168.1.126', 63149)
12:54:10 DNSServer: Domain: itunes.apple.com
12:54:10 DNSServer: ***forward request
12:54:10 DNSServer: -> DNS response from higher level
When I navigate to ATV Trailers, it says it can't connect. Try later. :(
PlexConnect seems to run fine. How about the certs?
I have them in assets/certificates. All three of them (cer key and pem). Should I generate them again?
Also installed to aTV?
Also you can load certs via network method:
https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Certificate-via-Ethernet
Reboot your aTV after loading them if it doesn’t work.
Yep. When I navigate to general/profile it says: trailers.apple.com
Remove them and reload, then reboot aTV.
Thats how I did it. Via network method.
Not working, reboot/power cycle aTV?
Removed it. Loaded it again. Do I have to load also the key and the pem? I ask, because you write 'them', plural...
I rebooted aTV too. Nothing changed.
Send me a pm. Only the trailer.cer:
http://trailers.apple.com/trailer.cer
The member wahlman.j cannot receive any new messages...
Really…one sec. My quota was full. That’s why I haven’t been getting messages. :stuck_out_tongue:
:-D
wahlman.j helped me out with personal assistence. He installed OpenPlex and everything works great now. Somehow, an old plist was conflicting causing the issues. But honestly, I don't know what he did and why it is working now. lol. I think he is some kind of magician. :D
Also, I would suggest to everyone getting to install PlexConnect that they try first with OpenPlex (https://forums.plex.tv/topic/108332-openplex-osx-app/).
Thank you again wahlman.j and also Baa for your kind help and your time.
Keep the good work up and hopefully you guys get a lot of donations.
