Can't get it to work
After one day of trying and trying, reading thread after thread in several forums, I am close to sell my ATV3 again because I am not able to get PlexConnect to work. I am a really sad panda.
I could follow every step in the manual and I repeated them several times. All I get is the Failed to connect to HTTP on 192.168.1.44 port 53: [Errno 48] Address already in use
I changed the Settings.cfg file to use port 80 instead and I get the same error message.
I am using a new iMac with the latest Mavericks build. I have Dropbox, Transmission, Airmail, Beamer, Firefox, Radium and Little Snitch installed (I have other software but they don't use Internet).
I use a RT-N16 Router. I have ports 53 and 80 completely open. Ah, and I changed my local IP to a static one.
What else should I do? Can someone please help me, I really don't have any knowledge to get this to work.
This is the complete message:
sudo "/Applications/PlexConnect-master/PlexConnect.py"
01:10:15 PlexConnect: ***
01:10:15 PlexConnect: PlexConnect
01:10:15 PlexConnect: Press CTRL-C to shut down.
01:10:15 PlexConnect: started: 01:10:15
01:10:15 PlexConnect: Version: 0.3.1+
01:10:15 PlexConnect: Python: 2.7.5 (default, Mar  9 2014, 22:15:05)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
01:10:15 PlexConnect: Host OS: darwin
01:10:15 PlexConnect: IP_self: 192.168.1.44
01:10:15 DNSServer: started: 01:10:15
01:10:15 DNSServer: ***
01:10:15 DNSServer: DNSServer: Serving DNS on 192.168.1.44 port 54.
01:10:15 DNSServer: intercept: ['trailers.apple.com'] => 192.168.1.44
01:10:15 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld.apple.com.edgesuite.net'] => 127.0.0.1
01:10:15 DNSServer: forward other to higher level DNS: 8.8.8.8
01:10:15 WebServer: started: 01:10:15
01:10:15 WebServer: Failed to connect to HTTP on 192.168.1.44 port 80: [Errno 48] Address already in use
01:10:15 PlexConnect: WebServer not alive. Shutting down.
01:10:15 PlexConnect: Shutting down.
01:10:20 DNSServer: Shutting down.
01:10:20 PlexConnect: shutdown
That error is saying that port 53 is in use on the plexconnect machine.
Have you rebooted and tried again?
I did just now and it didn't help. Still the same message. :(
Edit:
I tried to find out what is using port 53 and used the following command. Don't know how to read it though.
sudo lsof -i :53
COMMAND PID USER   FD   TYPE             DEVICE SIZE/OFF NODE NAME
Python  308 root    4u  IPv4 0x72e0d069cb9fb645      0t0  UDP 192.168.1.44:domain
You need to find out what is using port 53. If you want to debug start removing programs one by one until you find the culprit and check your listen port isnt 53 in your apache2 config in /etc/apache2/httpd.conf. List your current plists in /library/launchdaemons. Can you test with a different os/device to rule out a network issue? If you dont want to troubleshoot reinstall your os.
If you edited your settings.cfg as @bakman1 noticed maybe you should start with a fresh copy of PlexConnect with unedited settings (do not edit settings.cfg). That is for advanced settings typically.
thanks to all for joining in.
@wahlman.j: I am using a new setting.cfg since yesterday (actually I replaced the entire PlexConnect-master folder).
This is how it looks now:
11:02:47 PlexConnect: ***
11:02:47 PlexConnect: PlexConnect
11:02:47 PlexConnect: Press CTRL-C to shut down.
11:02:47 PlexConnect: started: 11:02:47
11:02:47 PlexConnect: Version: 0.3.1+
11:02:47 PlexConnect: Python: 2.7.5 (default, Mar  9 2014, 22:15:05)
11:02:47 PlexConnect: Host OS: darwin
11:02:47 PlexConnect: IP_self: 192.168.1.44
11:02:47 DNSServer: started: 11:02:47
11:02:47 DNSServer: Failed to create socket on UDP port 53: [Errno 48] Address already in use
11:02:47 PlexConnect: DNSServer not alive. Shutting down.
11:02:47 PlexConnect: Shutting down.
11:02:47 PlexConnect: shutdown
The problem of port 53 persists.
Regarding your other tips:
  • what is apache2 config in /etc/apache2/httpd.conf? Isn't this a server thing? I have Mavericks installed. Not using it as a server. Also, I have this computer since just 3 days. I am using the Mavericks the computer came with.
  • LaunchAgents has: com.nvidia.CUDASoftwareUpdate.plist
  • LaunchDaemons has: com.adobe.fpsaud.plist, com.apple.aelwriter.plist and com.apple.qmaster.qmasterd.plist
What about the python thing I posted earlier?
@bakman1: Don't know what this is... :( Any thoughts? It doesn't appear anymore...
Httpd.conf is a websever config file. See if it says listen 53. If not keep digging or refer to my previous post.
Sorry wahlman.j, I don't know where to find this file... could you give me a hint?
Using finder goto the top menu bar and choose goto folder in one of the menu dropdowns:
/etc
Apple likes to hide files. I assume this mac is used.
Well. Someone is sitting on your ports.
Do the lsof thing again, as requested up there.
>> sudo lsof -i :53
Looks like PlexConnect might already be running on your system, did you install the "daemon" stuff already? At that point you can't run it in a terminal again... But you won't need as everything should be good.
Is this the one in /user/library or top level /library?
PlexConnect will live inside the top level... running as root.
Log in as admin, do a sudo launchctl list | grep plexconnect. Will it show? Should come up with something like: 66 - com.plex.plexconnect.bash
Thanks wahlman.j. The httpd.conf says:
#Listen 12.34.56.78:80
Listen 1234
Listen 5050
Port 53 is not part of.
Also, this iMac should be new. At least it was completely sealed. And initially I could set it up as a new computer too. I did add some more memory, Fusion Drive and stronger graphic card, they probably did some test before sending it(?).
@Baa:
Yes, at the beginning, the first time I set PlexConnect up I run the daemon. I then used cd "/Applications/PlexConnect-master/support/OSX”
sudo ./uninstall.bash to uninstall it. I think there where some plist that I deleted manually...
Yes, the LaunchDaemons is root. Actually the user library doesn't have a LaunchDaemons, only a LaunchAgents. I run the sudo Isof again with port 53:
It still appears the same.
I run the sudo launchctl list and yes, it showed up like that:
96    -    com.plex.plexconnect.bash
What do I do now?
Unload and remove that file. It should be in /library/launchdaemons or /library/launchagents. Sounds to me that you used OpenConnect or openplex based on your httpd.conf (unrelated I think/hope)
Open terminal and type this when you navigate to the folder either:
cd /Library/LaunchDaemons
sudo launchctl unload com.plex.plexconnect.bash.plist
sudo rm com.plex.plexconnect.bash.plist
Or:
cd /Library/LaunchAgents
Use finder to find it first.
@baa smart use that to find the plist:
sudo launchctl list | grep plexconnect :slight_smile:
Well. PlexConnect is running on your machine already.
From my point of view: "Everythign is fine." :-D
What is your issue now?
Did you reboot you machine after deleting those plists? At that point, PlexConnect shouldn't run anymore...
You could also use "sudo kill 96" or something to get rid of it. You might have to kill all the daughter processes as well. So a reboot might be easier.
He already did... :-D
haha yes, I already did. Therefore it says: nothing found to unload.
And yes, I rebooted, but I am not sure if it was before or after deleting the plists... :(
Edit: And yes, I did use OpenConnect first, but didn't understand well how to use it and went the 'manual' way.
Start plexconnect with just terminal and see if it works now. Drag the plexconnect folder to a terminal window press enter then type this:
sudo ./plexconnect.py
Openconnect is now OpenPlex by the way. But get this working first then move on to other things if desired.
Do you mean with sudo /Applications/PlexConnect-master/PlexConnect.py? Because if yes, thats what I am trying all the time and what gives me the error message...
Drag the folder from finder to a terminal window not the file. Well either way should work hopefully now that you cleared your plists.
Edit- ya reboot would be a good idea
You got to close the first PlexConnect instance... reboot your system!
