Feb 27, 2019 13:09:54.788 [0x7fe4dfbef700] ERROR - [FFMPEG] - No NVENC capable devices found
Feb 27, 2019 13:09:54.788 [0x7fe4dfbef700] WARN - avcodec_open2 returned -542398533 for encoder 'h264_nvenc'
I don’t use nVidia on Linux workstations but do have it in the NAS. The nVidia GPU drivers must be on the LD_LIBRARY_PATH somewhere for it to work.
If you are doing a normal installation, they should show up in /lib or /lib64 (system defaults).
Thanks allot for your response, could you please elaborate on what it is I’m supposed to do to get Plex to recognize the drivers? (Copy or point Plex towards them) I installed the drivers the usual way through the official Nvidia PPA. Also rolled them back a couple of times to eliminate doubt. Lspci shows Nvidia properly and it’s the prime vga the system is using. nvidia-ims reports positive output.
Another note, I’m not sure if it’s important, I can’t get a video signal out of the quadro
The nvidia drivers should be on the default /lib64 and /lib LD_LIBRARY paths
If they aren’t installed there anymore, we’ll need to symlink them in.
Did you rerun ldconfig to have it update the links after installing and then reboot ?
On the QNAP boxes, which I just did this for 2 weeks ago, I appended the path to the drivers on LD_LIBRARY_PATH. This was an unusual but necessary step due to how QNAP does things. Their drivers end up in /opt
The drivers aren’t there, Could you be kind enough to guide me symlink the drivers to lib64 and /lib LD_LIBRARY paths? I’m unable to get it done. Thanks a million
Does nvidia-smi report the card properly? Did you reboot after installing the drivers?
Example nvidia-smi output:
# nvidia-smi
Wed Feb 27 17:52:54 2019
| NVIDIA-SMI 410.79 Driver Version: 410.79 CUDA Version: 10.0 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 Quadro P2000 Off | 00000000:13:00.0 Off | N/A |
| 53% 47C P0 18W / 75W | 149MiB / 5059MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 649 C /usr/lib/plexmediaserver/Plex Transcoder 62MiB |
| 0 4573 C /usr/lib/plexmediaserver/Plex Transcoder 77MiB |
Edit: You should not need to do anything after installing the drivers successfully and nvdia-smi reporting the card is there. Everything should be put into the proper paths.
Thanks for the feedback, nvidia-smi reports that the device and the driver are installed properly but still no go. i also tried modifying the path as chuck suggested with
export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/usr/lib/nvidia-390"
but i still can’t seem to be able to add a symlink for the drivers to lib and lib64
p600 is listed as a supported device on the even the latest nvidia drivers, so if you had errors involved with a newer driver then you should probably investigate that first.
I’ve been googling to my heart’s content for the past two days. although nvidia says it is compatible, the installer mentions that the Quadro P600 is supported through the legact 380.xx driver. i tried the 418 driver a few minutes ago just to confirm
no i didn’t get any 32bit compatibility issues, i’m running a 64bit system anyway.
The drivers link back to the official nvidia repositories, I guess they are all about the patch, I’ll give the patch a shot, maybe the replacement libraries would override whatever is holding the system back. Thanks for the tip. Cheers.
the patch is not going to fix it if the driver install says it doesn’t support the card.
the patch is a very simply modification of a few bit of data related only to the encoder code. the patch does not replace any libraries, it modified a file (making a backup copy first), thats it.
what I meant by providing the link was a list of known good linux drivers.
start with the newer ones if they dont’ work, uninstall and install the next older.
or start with the oldest and go forward, either way, you should be able to see what driver starts giving you the error.
What’s bugging me is that I don’t have any issues with the card nor the latest driver supported, it is Plex that can’t seem to recognize the card or see the drivers. I have tried to install the drivers from both the Official Ubuntu PPA and direct .run file versions from the nvidia website.
Good to know how the patch works though and I’ll try the drivers they provide, fingers crossed and thanks allot once again.
