Now for the news:
- It can’t see the onboard ASIC in the CPU
- It can’t use/see the Nvidia.
Apr 06, 2020 14:51:20.156 [0x7fa5d8dd6700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Apr 06, 2020 14:51:20.156 [0x7fa5d8dd6700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error
Apr 06, 2020 14:51:20.156 [0x7fa5d8dd6700] DEBUG - Codecs: testing h264_nvenc (encoder)
Apr 06, 2020 14:51:20.156 [0x7fa5d8dd6700] DEBUG - Codecs: hardware transcoding: testing API nvenc
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] ERROR - [FFMPEG] - Cannot load libcuda.so.1
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] ERROR - [FFMPEG] - Could not dynamically load CUDA
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Unknown error occurred
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - Codecs: testing mpeg4 (decoder) with hwdevice vaapi
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - Codecs: hardware transcoding: opening hw device failed - probably not supported by this system, error: Input/output error
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - Codecs: testing mpeg4 (decoder) with hwdevice nvdec
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - Codecs: hardware transcoding: testing API nvdec
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - Scaled up video bitrate to 2554Kbps based on 1.500000x fudge factor.
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - MDE: Selected protocol dash; container: mp4
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - MDE: analyzing media item 33
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - MDE: An Act of War (2015): Direct Play is disabled
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - MDE: An Act of War (2015): media must be transcoded in order to use the dash protocol
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - MDE: An Act of War (2015): no direct play video profile exists for http/avi/mpeg4
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - MDE: An Act of War (2015): no direct play video profile exists for http/avi/mpeg4/ac3
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - MDE: An Act of War (2015): avoiding video remux due to potentially unsafe container/codec combination
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - MDE: An Act of War (2015): no remuxable profile found, so video stream will be transcoded
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - Codecs: testing h264_nvenc (encoder)
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - Codecs: hardware transcoding: testing API nvenc
Apr 06, 2020 14:51:20.157 [0x7fa5d8dd6700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Please go look at /dev/dri and see if there’s anything listed there.
“renderD128” and “renderD129” both being listed means the kernel sees the hardware.
