Server Version#: 1.32.4.7164 (Windows)
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Hi All.
I moved servers recently - I’m using the same post-processing script I’ve used for years on the new server. For whatever reason, I can’t seem to get Plex to invoke it. I’ve got the script in the correct folder in AppData and I’ve even used “copy path” to ensure I haven’t fat-fingered the filename or path. I’ve also cleaned out the quotes it adds, etc. Nothing works.
I’ve tried digging through the logs, but am not sure if I’m looking at the right now. Any guidance on any of this?
Thanks! Will.
