Hi everybody,
I’m struggling to install PMS on my Synology.
I had Plex inside Docker, I want to move it on native.
What I did:
- disconnect PMS and user
- cancel (not remove) the PMS in docker
- turn off docker
- reboot
- download plex from packet centre
What I get: The port 32400 is already configured or used and it’s in conflict.
Netstats show that there is no port 32400 in use.
Reboot, wait, try again. Nothing.
Restarted Docker, restarted PMS on docker, stopped again, cancelled again, stopped Docker, Rebooted. Same problem.
Restarted Docker, renamed Preferences.xml.old, restarted PMS, reclaimed the server, disconnected, stopped, cancelled, stopped docker, rebooted. Same problem.
At this point, I’m missing something. Synology does not let go of port 32400 for some reasons. I really don’t know what to try next.
If anybody has any suggestion it will be appreciated.
Thank you very much, tAlpA
it was so simple…
