Cant pin or find Live TV in sidebar
Server Version#: 1.42.2.10156
Player Version#: 4.147.1
I cant pin or open Live TV in my Plex installation using sidebar. Live TV itself works correctly, and I can access it directly using the URI:
/web/index.html#!/live-tv
However, I’m no longer able to add Live TV to the sidebar normally. Previously, in my profile settings, there was a checkbox that allowed enabling or disabling Live TV in the sidebar, but this option has disappeared. What could be the issue?
Put the side bar into the MORE… mode
Scroll the sidebar all the way down, to where the online media sources are listed.
There should be another “Live TV” item there.
That same item will move upwards among your server’s libraries, if you disable “Live TV” on this page https://app.plex.tv/desktop/#!/settings/online-media-sources
(you might have to refresh the web app in your browser after toggling this)
