Can't play audio since 0.4
Hi, here my problem :
  • Size of Raspberry Pi (256, 512)
​512
  • Type of SD card
Sandisk ultra SDHC I
  • Internet connection type (Ethernet or Wifi)
​Ethernet
  • Version of RasPlex (if not the latest, please see if the problem exists on latest first)
Latest (0.4)
  • Log files
http://pastebin.com/pfe7E8ff
  • How did you install rasplex? (gui installer, win32 disk imager, what platform OSX/Win/Linux?)
​win32 disk imager on windows 8
  • Best description you can give of the problem
Launch any mp3 file
  • Steps to reproduce (what were you doing when it happened? Can you make it happen again?)
From the previous version, I did an upgrade within Rasplex, Now Rasplex is trying to transcode my mp3 to mjpeg, seems it believes it's a video format now... My files are on a NAS (openmediavault running rasplex server)
Totally lost...
​512
  • Type of SD card
​Ethernet
Latest (0.4)
  • Log files
Launch any mp3 file
Totally lost...
Did you try searching this forum before posting, there are a number of posts from yesterday regarding this issue, see this post and others:
https://forums.plex.tv/topic/102612-rasplex-040-rc1-is-out/?p=605624
Oh sorry, I did search the forum (page 1 to 3 regarding audio, stoped before the released date), from your post I did not read the 7 pages, sorry....
Just another thing, why did my autoupdate bring me from a stable to a non working RC relaese ?
I'm not sure. It should have been kept separate from the 'stable' release channel, just like the preceding betas have been.
But since a 'release candidate' is not the same category as an 'experimental beta', it must have slipped through somehow.
The previous stable release is now VERY old, and I guess its autoupdate routines may have had different categories than the new ones... :(
Most of the people involved with beta testing and development would tend to miss such a mistake, as they already used beta versions.
Best regards: dlanor
HA, ok, thanks ! Not so serious... (It's my wife, she's unhappy about the music :) )
Tell your wife it shouldn't be too long since we have a version fixing this :)
She's getting angry, asking me why I had to update, since it worked okay till the update....  :wub:
You can always manually flash back and cancel auto update
and loose my settings ?
How much is needed? I bet you can time it up in 5 minutes
Sent from my Nexus 4 using Tapatalk
I don't think the 'preferences' settings are the main issue here, but rather the pre-caching needed to get decent GUI response speed.
And the pre-caching can take much longer than 5 minutes, especially with a large Plex library.
Even so, in his place I'd bite the bullet and just do it, to restore peace with the spouse... ;)
ha, ok ! I'll do it then. Should I set pre caching to 100 % ?
