Plex was having multiple problems…dvr not working right and not parsing movie metadata correctly so I uninstalled Plex by doing:
sudo dpkg -r plexmediaserver
sudo rm -r /var/lib/plexmediaserver
Then I try to install it using:
sudo dpkg -i plexmediaserver_1.11.3.4803-c40bba82e_amd64.deb
From the logs:
Mar 6 10:32:22 Zarkov systemd[1]: Starting Plex Media Server for Linux…
Mar 6 10:32:22 Zarkov systemd[1]: Started CUPS Scheduler.
Mar 6 10:32:22 Zarkov systemd[1]: Started ACPI event daemon.
Mar 6 10:32:22 Zarkov sh[6191]: /bin/mkdir: cannot create directory ‘/var/lib/plexmediaserver’: Permission denied
Mar 6 10:32:22 Zarkov systemd[1]: plexmediaserver.service: Control process exited, code=exited status=1
Mar 6 10:32:22 Zarkov systemd[1]: Failed to start Plex Media Server for Linux.
Mar 6 10:32:22 Zarkov systemd[1]: plexmediaserver.service: Unit entered failed state.
Mar 6 10:32:22 Zarkov systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
If I manually create the /var/lib/plexmediaserver I just get another error…not sure what kind of quality control is going on…the next new error is:
Mar 6 10:45:09 Zarkov systemd[1]: Starting Plex Media Server for Linux…
Mar 6 10:45:09 Zarkov systemd[1]: Started Plex Media Server for Linux.
Mar 6 10:45:10 Zarkov systemd[1]: Reloading.
Mar 6 10:45:10 Zarkov systemd[1]: [/etc/systemd/system/plexmediaserver.service:11] Invalid escape sequences in line, correcting: “/bin/sh -c ‘LD_LIBRARY_PATH=/usr/lib/plexmediaserver /usr/lib/plexmediaserver/Plex\ Media\ Server’”
Mar 6 10:45:11 Zarkov sh[6998]: Error in command line:the argument for option ‘–serverUuid’ should follow immediately after the equal sign
Mar 6 10:45:11 Zarkov sh[6998]: Crash Uploader options (all are required):
Mar 6 10:45:11 Zarkov sh[6998]: --directory arg Directory to scan for crash reports
Mar 6 10:45:11 Zarkov sh[6998]: --serverUuid arg UUID of the server that crashed
Mar 6 10:45:11 Zarkov sh[6998]: --userId arg User that owns this product
Mar 6 10:45:11 Zarkov sh[6998]: --platform arg Platform string
Mar 6 10:45:11 Zarkov sh[6998]: --url arg URL to upload to
Mar 6 10:45:11 Zarkov sh[6998]: --help show help message
Mar 6 10:45:11 Zarkov sh[6998]: --version arg Version of the product
