Can't scrub when paused anymore in v2.0 (12011)
Just grabbed the 2.0 (12011) release from Test Flight. Playing an mkv and right off the bat the remote and remote app behavior is quite different. I can no longer scrub through the timeline at all.
Was this intended behavior? Wanted to make sure that it’s indeed a bug. Thanks!
Does turning off the enhanced player help?
See also: Pause And Scrubbing
Just downloaded 12011 on my Apple TV 4th gen (1080p), the first test was on my ATV4k.
Confirmed that I can turn off the Enhanced Player on both ATVs and scrubbing works again. I don’t get the dimmed screen like on the other post on either however. Screen stays active.
Back to regular player, till the next build.
Thanks, you do have to disable it for scrubbing to work.
Mee too in 12011
unable to scrub and resume playback in enhanced player.
when I disable enhanced player, it all works again.
same behaviour overhere
Such a simple error, should have been noticed before it went out.
Same here, with beta versions stuff can break so will rollback using testflight for now.
Thanks for the reports, we’ll be pushing a new beta with a fix shortly.
For now you can either turn off the Enhanced Player, or roll back to an earlier version.
