Not sure if anyone else is running into this. When I pause the screen goes dim and I can’t scrub at all. Tested on both my Apple TV 4th gen and Apple TV 4K
Same here. I also can’t resume play with the play/pause button on the ATV remote.
I can replicate this but only when the enhanced player is enabled.
The screen doesn’t go dim when I pause, but I can’t scrub or resume playback with the remote, the only way to resume playback is with a tap on the touch pad of the remote app in Control Center!
guess i won’t be installing the beta then
Yes.
Enhanced player breaks it.
Normal one works.
