Thanks. I’ve uninstalled, downloaded the last version and reinstalled without altering anything.
The service still refuses to run properly.
The only way I’ve found so far is to run the manual script from a terminal
nohup ./start-pms.sh
Please do the following:
Done points 1 to 4
The service still fails to start
Done points 5 to 6, how can I push the files to you?
DM sent.
These logs are from last evening (your time).
Everything appears to be running.
How did you start PMS to obtain this?
I’ve finally found something interesting.
There are 2 different spins of fedora server: DVD and netinstall
https://getfedora.org/server/download/
The PMS service won’t run on a fedora if installed with netinstall spin.
Very interesting.
For clarification so I may reproduce,
Is this correct?
That’s correct, for 28 and 29 netinstall versions of fedora
