Server Version#: plexmediaserver-1.15.1.791-8bec0f76c.x86_64.rpm
good afternoon.
I have installed the package on a headless machine with a fedora 29 server on it.
I just can’t run pms on it.
I’ve set selinux to permissive and disabled the firewall for tests.
systemctl status plexmediaserver
● plexmediaserver.service - Plex Media Server
Loaded: loaded (/usr/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: disabled)
Active: failed (Result: core-dump) since Sun 2019-03-17 00:01:33 CET; 18min ago
Process: 1248 ExecStart=/bin/sh -c PLEX_MEDIA_SERVER_INFO_VENDOR="$(grep ^NAME= /etc/os-release | awk -F= "{print \$2}" | tr -d \" )" PLEX_MEDIA_SERVER_INFO_DEVICE="PC" PLEX_MEDIA_SERVER_INFO_MODE>
Process: 1246 ExecStartPre=/bin/sh -c /usr/bin/test -d "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "${PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" (code=exited, status=0/SUCCESS)
Main PID: 1248 (code=dumped, signal=ABRT)
mars 17 00:01:28 QNAP.localdomain systemd[1]: plexmediaserver.service: Main process exited, code=dumped, status=6/ABRT
mars 17 00:01:28 QNAP.localdomain systemd[1]: plexmediaserver.service: Failed with result 'core-dump'.
mars 17 00:01:33 QNAP.localdomain systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
mars 17 00:01:33 QNAP.localdomain systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
mars 17 00:01:33 QNAP.localdomain systemd[1]: Stopped Plex Media Server.
mars 17 00:01:33 QNAP.localdomain systemd[1]: plexmediaserver.service: Start request repeated too quickly.
mars 17 00:01:33 QNAP.localdomain systemd[1]: plexmediaserver.service: Failed with result 'core-dump'.
mars 17 00:01:33 QNAP.localdomain systemd[1]: Failed to start Plex Media Server.
after the installation I’ve set selinux to permissive mode.
sudo chown -R plex:plex /var/lib/plexmediaserver
It hasn't changed anything
the result of sudo journalctl -xe | grep -i plex
[code]
mars 17 10:51:00 QNAP.localdomain dbus-daemon[771]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.93' (uid=0 pid=1837 comm="sudo chown -R plex:plex /var/lib/plexmediaserver " label="unconfined_u:unconfined_r:unconfined_t:s0-s0:c0.c1023")
mars 17 10:51:09 QNAP.localdomain sudo[1837]: jyl : TTY=pts/0 ; PWD=/home/jyl ; USER=root ; COMMAND=/usr/bin/chown -R plex:plex /var/lib/plexmediaserver
mars 17 10:51:11 QNAP.localdomain sudo[1844]: jyl : TTY=pts/0 ; PWD=/home/jyl ; USER=root ; COMMAND=/usr/bin/chown -R plex:plex /var/lib/plexmediaserver
mars 17 10:51:28 QNAP.localdomain sudo[1867]: root : TTY=pts/0 ; PWD=/home/jyl ; USER=root ; COMMAND=/usr/bin/systemctl stop plexmediaserver
mars 17 10:51:34 QNAP.localdomain sudo[1874]: root : TTY=pts/0 ; PWD=/home/jyl ; USER=root ; COMMAND=/usr/bin/systemctl start plexmediaserver
mars 17 10:51:34 QNAP.localdomain systemd[1]: Starting Plex Media Server...
-- Subject: L'unité (unit) plexmediaserver.service a commencé à démarrer
-- L'unité (unit) plexmediaserver.service a commencé à démarrer.
mars 17 10:51:34 QNAP.localdomain audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=plexmediaserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 17 10:51:34 QNAP.localdomain systemd[1]: Started Plex Media Server.
-- Subject: L'unité (unit) plexmediaserver.service a terminé son démarrage
-- L'unité (unit) plexmediaserver.service a terminé son démarrage, avec le résultat done.
mars 17 10:51:34 QNAP.localdomain audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=plexmediaserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
mars 17 10:51:34 QNAP.localdomain systemd[1]: plexmediaserver.service: Main process exited, code=dumped, status=6/ABRT
mars 17 10:51:34 QNAP.localdomain systemd[1]: plexmediaserver.service: Failed with result 'core-dump'.
mars 17 10:51:34 QNAP.localdomain systemd-coredump[1892]: Process 1880 (Plex Media Serv) of user 987 dumped core.
#11 0x00000000013da77b n/a (Plex Media Server)
#12 0x0000000001419dbd n/a (Plex Media Server)
#14 0x000000000048711e n/a (Plex Media Server)
-- Subject: Le processus 1880 (Plex Media Serv) a généré un fichier « core »
-- Le processus 1880 (Plex Media Serv) a planté et généré un fichier « core ».
mars 17 10:51:35 QNAP.localdomain abrt-server[1900]: Package 'plexmediaserver' isn't signed with proper key
mars 17 10:51:39 QNAP.localdomain systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
mars 17 10:51:39 QNAP.localdomain systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 1.
-- Le redémarrage automatique de l'unité (unit) plexmediaserver.service a été planifié, en
mars 17 10:51:39 QNAP.localdomain audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=plexmediaserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 17 10:51:39 QNAP.localdomain audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=plexmediaserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 17 10:51:39 QNAP.localdomain systemd[1]: Stopped Plex Media Server.
-- Subject: L'unité (unit) plexmediaserver.service a terminé son arrêt
-- L'unité (unit) plexmediaserver.service a terminé son arrêt.
mars 17 10:51:39 QNAP.localdomain systemd[1]: Starting Plex Media Server...
mars 17 10:51:39 QNAP.localdomain systemd[1]: Started Plex Media Server.
mars 17 10:51:40 QNAP.localdomain systemd[1]: plexmediaserver.service: Main process exited, code=dumped, status=6/ABRT
mars 17 10:51:40 QNAP.localdomain systemd[1]: plexmediaserver.service: Failed with result 'core-dump'.
mars 17 10:51:40 QNAP.localdomain audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=plexmediaserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
mars 17 10:51:40 QNAP.localdomain systemd-coredump[1917]: Process 1905 (Plex Media Serv) of user 987 dumped core.
-- Subject: Le processus 1905 (Plex Media Serv) a généré un fichier « core »
-- Le processus 1905 (Plex Media Serv) a planté et généré un fichier « core ».
mars 17 10:51:40 QNAP.localdomain abrt-server[1923]: Package 'plexmediaserver' isn't signed with proper key
mars 17 10:51:45 QNAP.localdomain systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
mars 17 10:51:45 QNAP.localdomain systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 2.
mars 17 10:51:45 QNAP.localdomain audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=plexmediaserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 17 10:51:45 QNAP.localdomain audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=plexmediaserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 17 10:51:45 QNAP.localdomain systemd[1]: Stopped Plex Media Server.
mars 17 10:51:45 QNAP.localdomain systemd[1]: Starting Plex Media Server...
mars 17 10:51:45 QNAP.localdomain systemd[1]: Started Plex Media Server.
mars 17 10:51:45 QNAP.localdomain systemd[1]: plexmediaserver.service: Main process exited, code=dumped, status=6/ABRT
mars 17 10:51:45 QNAP.localdomain systemd[1]: plexmediaserver.service: Failed with result 'core-dump'.
mars 17 10:51:45 QNAP.localdomain audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=plexmediaserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
mars 17 10:51:45 QNAP.localdomain systemd-coredump[1940]: Process 1928 (Plex Media Serv) of user 987 dumped core.
-- Subject: Le processus 1928 (Plex Media Serv) a généré un fichier « core »
-- Le processus 1928 (Plex Media Serv) a planté et généré un fichier « core ».
mars 17 10:51:46 QNAP.localdomain abrt-server[1946]: Package 'plexmediaserver' isn't signed with proper key
mars 17 10:51:50 QNAP.localdomain systemd[1]: plexmediaserver.service: Service RestartSec=5s expired, scheduling restart.
mars 17 10:51:50 QNAP.localdomain systemd[1]: plexmediaserver.service: Scheduled restart job, restart counter is at 3.
mars 17 10:51:50 QNAP.localdomain systemd[1]: Stopped Plex Media Server.
mars 17 10:51:50 QNAP.localdomain systemd[1]: plexmediaserver.service: Start request repeated too quickly.
mars 17 10:51:50 QNAP.localdomain audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=plexmediaserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 17 10:51:50 QNAP.localdomain audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0 msg='unit=plexmediaserver comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
mars 17 10:51:50 QNAP.localdomain systemd[1]: plexmediaserver.service: Failed with result 'core-dump'.
mars 17 10:51:50 QNAP.localdomain systemd[1]: Failed to start Plex Media Server.
-- Subject: L'unité (unit) plexmediaserver.service a échoué
-- L'unité (unit) plexmediaserver.service a échoué, avec le résultat failed.
[/code]
Did you customize /lib/systemd/system/plexmediaserver.service ? If you did, it will be overwritten when next updated. Proper customization uses /etc/systemd/system/plexmediaserver.service.d/override.conf I have a customization tip to guide in that.
Plex, on Fedora, “just works”. I know this because my daily driver/development system is Fedora 28. Are you running on the Rawhide branch? If so, that will cause craziness for certain.
As for running Fedora on a QNAP box, while the QNAP is “just a computer”, the only thing we have done is run Ubuntu. Never tried fedora.
Are you up to constructing a manual start shell script?
copy out the Environment= lines from the .service file. Make them export statements in a new script
In that same script, copy out the ExecStart and make that the command invoked by the script after the environment is set.
Save and chmod +x it.
Done correctly, you now have a manual launch and being in your TTY, you see all errors PMS prints.
I’ve just built a fresh VM with F29 server netinstall and done the same with F28
I just enabled RPM fusion on it, and installed plex.
Also performed sudo chown -R plex:plex /var/lib/plexmediaserver
I’ve just created a VM with F28 workstation, the service runs well on it.
It doesn’t run on F28 server
I don’t have time to try but my guess is that it will work with F29 workstation.
Good afternoon
The script is not not working
I’ve edited it to have proper locale
#!/bin/sh
echo Starting PMS for diagnostics
PLEX_DIR="/usr/lib/plexmediaserver"
PID_FILE="/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/plexmediaserver.pid"
PLEX_USER=plex
# Continue with normal PMS start
su $PLEX_USER -s /bin/sh -c \
"export LC_ALL=fr_FR.utf8; \
export LANG=fr_FR.utf8; \
export LD_LIBRARY_PATH='$PLEX_DIR/lib'; \
export PLEX_MEDIA_SERVER_MAX_PLUGIN_PROCS=6; \
export PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR='/var/lib/plexmediaserver/Library/Application Support'; \
export TMPDIR=/var/lib/plexmediaserver/tmp_transcoding; \
/usr/lib/plexmediaserver/Plex\ Media\ Server"
# kill it (set trap to execute this if desired) and force a crash dump
sudo kill -11 $(pidof "Plex Media Server")
what I get on the command line:
[root@QNAP jyl]# ./start-pms.sh
terminate called after throwing an instance of 'std::runtime_error'
what(): Codecs: Initialize: 'boost::filesystem::temp_directory_path: Not a directory: "/var/lib/plexmediaserver/tmp_transcoding"'
****** PLEX MEDIA SERVER CRASHED, CRASH REPORT WRITTEN: /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Crash Reports/1.15.1.791-8bec0f76c/PLEX MEDIA SERVER/1fbc1a79-e648-e16b-732920cb-30e58399.dmp
Error in command line:the argument for option '--serverUuid' should follow immediately after the equal sign
Crash Uploader options (all are required):
--directory arg Directory to scan for crash reports
--serverUuid arg UUID of the server that crashed
--userId arg User that owns this product
--platform arg Platform string
--platformVersion arg Platform version string
--vendor arg Vendor string
--device arg Device string
--model arg Device model string
--sentryUrl arg Sentry URL to upload to
--sentryKey arg Sentry Key for the project
--version arg Version of the product
sh : ligne 1 : 1170 Abandon (core dumped)/usr/lib/plexmediaserver/Plex\ Media\ Server
kill: pas assez d'arguments
Thanks.
I’ve set the tmp dir to /tmp and it works.
I’ve been able to launch pms, configure a directory and access a movie from a client.
What is the next step to get a fully functional service?
First, you do not alter /lib/systemd/system/plexmediaserver.service. This is controlled by the package manager. You use the proper and supported systemd override mechanism.
I do not recommend changing the server’s core language. I do suggest you change the default language (plex.tv) and display language (Setting - Web).
Should you wish to consider this avenue:
You will want to create the override file as follows using the above procedure.
