Car View Doesn't work when Phone is Horizontal
My server is on Version 1.20.2.3402.
Google Pixel Phone Android 10
Plexamp 3.2.2
I have Car View enabled on my phone. I noticed today while driving that the larger icons and less cluttered Car View option only works if the phone is mounted or held Vertically. When the Phone is Horizontal the display is the regular display.
It would be nice if Car View worked in both Vertical and Horizontal mode. As some cars mounting your phone Horizontally is better.
Is this possible?
correct, there is no landscape Car View yet, we wanted to see how people liked/used the portrait mode one before investing the effort :sweat_smile:
Well that is just logical, smart and reasonable. :laughing:
If its worth anything I like the Car View. It is way easier to tap a larger button to skip and easier to see. My car doesn’t support android auto so I have to mount my phone to the dash.
Also this might need to be a different post. But have you thought about multiple EQ Presets? For example, a Car EQ preset and a Headphones EQ preset? Or maybe the User can create an EQ and then save it as Preset 1 Car. Preset Headphones. Or is this another feature that you are checking to see if people like EQ’s. :laughing:
yes :slight_smile: not high on the list atm but something we’d like to do
