Caster - An Application Launcher (inspired by AppTV)
[quote name=“myspacee” post=“814741” timestamp=“1420538095”]
Hello,
read all 6 pages but can’t figure how create working Caster channel.
Follow instruction alway create a Plugin folder named ‘caster_my_application_caster.bundle’
also if i specify name in right section.
Channel is created but if i run it, nothing happen.
I want to run an emulator to allow my child play on tv using PLEX.
Anyone can post folder zip of working caster channel ?
(eg: running an .exe)
this caster should launch steam in big picture mode Ian Urquhart shared “Steam big pictute”: https://onedrive.live.com/redir?resid=CCCE24791C3FBFB1!17406&authkey=!AHg__M2KAwjv7p4&ithint=folder%2c
Perhaps there should be a separate Mac OS version because I still can't get Caster to work. I haven't seen any recent post to resolve the Channel error. If any iMac users have got Caster to work with the latest OS, please provide instructions.
Thank you Z,
i'm at work now, try later.
thank you again,
m.
Hello,
try and try again without luck.
Post my (not working) channel to shutdown PC.
It simple run a batch placed in c:\script\shutdown.bat
Need this because my ipad client has not an option to remote shutdown server.
I hope Caster will be fixed for newer Plex version.
thank you again,
m.
I have downloaded the working tree version from Github and still no luck. I'm no longer getting "This Chanel is no available", but I'm still unable to complete the "create caster step" The current error is: "Could not find the plug-in folder; please check your installation: /Users/debrapreyerPlug-ins\"
I moved the plugin to folder specified and I am still receiving the same error. Please provide clear instructions specifically for Mac users.
