As the title states, the Categories (Pivot) tab is blank, on personal media TV libraries.
Checking the release notes, the feature was added under:
(Pivots) Add genre categories to Movies and TV Shows libraries (#12309 )
A screenshot of what I see, when clicking the Categories tab, on a TV library:
The screenshot is from Plex Web but I have verified that no categories are displayed on iOS, Samsung (Tizen) and Android TV too.
There is no issue with my Movies / Films library - Categories are correctly displayed on all the same clients. The issues is isolated to TV libraries.
Let me know if there is anything I can do to assist.
Thanks.
tom80H
August 16, 2022, 2:53pm
2
I assume your tv shows have genres assigned to them? Just double checking because you specifically mentioned „personal media“.
Poor wording on my part… This is a TV library and uses Plex TV Series agent & scanner, which has auto-populated the Genre fields:
For completeness, I had Movies & TV option under Online Media Sources disabled but quickly enabled and verified that the Categories show up fine there too.
tom80H
August 16, 2022, 5:46pm
4
Ok… I can confirm this on my own setup – that’s a weird one. Let me see if I can forward this…
Thanks for confirming.
I’ve just checked my log file and the below entries get added:
Aug 16, 2022 18:56:15.426 [0x1532fb955b00] Debug — Request: [*********** (WAN)] GET /library/sections/2/categories?includeCollections=1&includeExternalMedia=1&includeAdvanced=1&includeMeta=1 (15 live) #20b6b TLS Page 0-49 GZIP Signed-in Token (JStrongy) (Microsoft Edge)
Aug 16, 2022 18:56:15.460 [0x1532fb955b00] Error — [Req#20b6b] Unknown metadata type: directory
Let me know if you need anything further.
Update: Loaded 1.28.1.6092 on my Synology NAS. TV Show categories now working in Plex Web. It was not working on the previous release, 1.28.1.6057.
Maybe fixed in latest beta?
(Pivots) Genres may not be shown for tv shows in some cases (#13751 )
Plex Media Server 1.28.1.6092 is now available to Plex Pass users in the Beta update channel.
NEW:
(Debian) Reduced external command usage 80% during installation
(Debian) repository signing upgraded to use GPG signing key Ubuntu 20+ and Debian 10+
(Pivots) Add genre categories to Movies and TV Shows libraries (#12309)
(Transcoder) Improved subtitle burning compatibility and performance
(Transcoder) Support reporting more detailed HDR metadata information in HLS manifests
FIXES:
(Debian) I…
Updated to v1.28.1.6092 and that’s sorted it!
I really wish users had an option to disable this “feature”.
Can’t you just not use it?
I would prefer it not be shown with my movies or shows
The error still appears with me! I have the latest version
With series it works, but very slowly
with movies it does not load at all and an error message appears
When searching the forums when I had this initial issue, I came around various posts from users with large libraries, where the Categories view takes a while to load or just times out.
I believe the PMS logs highlighted a slow running query, so doesn’t look like the Categories are cached.
system
Closed
November 29, 2022, 7:02am
14
