Cayars - Setup walk through and some tips and tricks
Some impressive stats, to say the least. You're on a Verizon Fiber connection right? I can't image uploading a backup to Amazon like that... it would take me so long...
Sorry, try again. I was shuffling some files around on my storage pool and forgot about this one. :(
All fixed.
Carlo
Trying the script but getting this when i run it:
F:\Seedbox_transfers\Convert>E:\python27\python.exe manual.py -a -i F:\Seedbox_t
ransfers\Convert\process\
Traceback (most recent call last):
  File "manual.py", line 11, in
    from readSettings import ReadSettings
  File "F:\Seedbox_transfers\Convert\readSettings.py", line 9, in
    from babelfish import Language
  File "F:\Seedbox_transfers\Convert\babelfish\__init__.py", line 20, in
    from .converters import (LanguageConverter, LanguageReverseConverter, Langua
geEquivalenceConverter, CountryConverter,
  File "F:\Seedbox_transfers\Convert\babelfish\converters\__init__.py", line 6,
in
    from pkg_resources import iter_entry_points, EntryPoint
ImportError: No module named pkg_resources
Set my run.bat:
E:\python27\python.exe manual.py -a -i F:\Seedbox_transfers\Convert\process\
and my Autoprocess.ini
[MP4]
ffmpeg = ffmpeg.exe
ffprobe = ffprobe.exe
output_directory = F:\Seedbox_transfers\Converted\Done
output_extension = mp4
output_format = mp4
delete_original = True
audio-codec = ac3,mp3,dts,dca
video-codec = h264,x264
video-bitrate =
ios-audio = True
ios-first-track-only = True
audio-language = eng,fre
audio-default-language = eng
audio-channel-bitrate = 256
subtitle-language = eng,fre
subtitle-default-language =
convert-mp4 = True
download-artwork = False
fullpathguess = True
tag-language = en
copy_to =
download-subs = False
move_to =
max-audio-channels =
tagfile = False
embed-subs = False
subtitle-codec = srt
video-max-width =
permissions = 777
relocate_moov = False
sub-providers = addic7ed, podnapisi, thesubdb, opensubtitles
Also is that the right abbreviation for french?
Change your french country code to “fra”.
Change your french country code to "fra".
same issue
in
Could you post your most recent ini file?
BTW, did you try it using just “eng” to see if the problems go away? Just want to narrow down the issue.
Will try as soon as i get home
Sent from my SM-G920W8 using Tapatalk
I tried your two line changes as eng,fra and it works fine for me.
same error with just english
Three quick questions for you.
You installed Python 2.7 and not a 3.x release correct?
This is running on Windows correct?
No idea if this matters but what is the default language setup on your computer?
Since you have multiple drives and paths mentioned where did you install “Convert” to? IE if it’s F:\Convert then try opening a command box, switching to that directory which should have the run.bat in it and then type run. Probably no help at all but simple enough to test (just in case).
If Python is 2.7, Windows and English (default language) then I’d suggest going back to basics and removing the existing Convert directory and unzipping it again.
Change nothing to start with except the output_directory setting in the ini file and try it again to see what happens.
This way we’ll know if something else might have gotten changed by accident or not.
Carlo
PS continue to use the same directory structure and run.bat as they should be fine.
If replacing the convert zip files works then make changes to the ini one step at a time and test until you get to the trouble line.
Since you have multiple drives and paths mentioned where did you install "Convert" to? IE if it's F:\Convert then try opening a command box, switching to that directory which should have the run.bat in it and then type run. Probably no help at all but simple enough to test (just in case).
If Python is 2.7, Windows and English (default language) then I'd suggest going back to basics and removing the existing Convert directory and unzipping it again.
This way we'll know if something else might have gotten changed by accident or not.
Carlo
I tried just extracting into my C drive and i open run.bat and edited it to
python manual.py -a -i c:\convert\process
My python path is in my environment variables since i use python 2.7 for Sickrage
Im on windows server 2012 r2 std english and using python 2.7.8 located in my E drive
C:\Convert>python
Python 2.7.8 (default, Jun 30 2014, 16:08:48) [MSC v.1500 64 bit (AMD64)] on win
32
Type "help", "copyright", "credits" or "license" for more information.
>>> ^Z
C:\Convert>run.bat
C:\Convert>python manual.py -a -i c:\convert\process
File “manual.py”, line 11, in
File “C:\Convert\readSettings.py”, line 9, in
File “C:\Convert\babelfish_init_.py”, line 20, in
File “C:\Convert\babelfish\converters_init_.py”, line 6, in
Thank you for doing that. I too am running Windows 2012 R2 English with Python 2.7.8. My Python is installed on C drive but that doesn’t appear to be the issue.
For the errors shown is this with the fresh unpacked ZIP file without any mods except the output parameter in the ini file? IE no languages changed?
Carlo
Right. All I changed was my path to Python
Lol… Stupid question… Is this self contained script or does it need handbrake.
We're going to figure this out!
By any chance do you have another computer you could test it on just to see if maybe it's a computer thing and help us narrow it down?
Thus far this is the first computer/installation with issues so I want to get this figured out.
Lol... Stupid question.. Is this self contained script or does it need handbrake.
No it does not use handbrake but instead uses ffmpeg internally. You do however need to install python 2.7.x if not already installed. That's the only pre-requisite.
Carlo
Ok… I will test on another machine in about 20min(communiting atm) . Also does using Python 64bit a issue?
Ok.. I will test on another machine in about 20min(communiting atm) . Also does using Python 64bit a issue?
Ok...i narrowed down the problem to being Python 64bit. I tried it on another machine that did not have python. I installed python 2.7.8 64bit and it failed with the same error. Then i removed the 2.7.8 and installed 2.7.10 32 bit and it worked.
@cayars
You need to add "fre" as French language abbreviation be i was unable to get your script to add the french audio because the settings doesnt access "fre". Using "fra" did not get the audio french in output file
E:\Tools\Convert>e:\python27_x86\python manual.py -a -i F:\Seedbox_transfers\Con
verted\process
Manual processor started.
32bit Python.
Processing file F:\Seedbox_transfers\Converted\process\Mortdecai 2015 Multi BluR
ay 1080p DTS-HD MA 7.1 x264-HD Workshop.mkv
Reading video stream.
Video codec detected: h264
Reading audio streams.
Audio detected for stream #1: dca [eng].
Creating audio stream 0 from source audio stream 1 [AAC-audio].
Creating audio stream 1 from source audio stream 1.
Audio detected for stream #2: ac3 [fre].
Creating audio stream 2 from source audio stream 2.
Reading subtitle streams.
Subtitle detected for stream #3: pgssub [eng].
Subtitle detected for stream #4: pgssub [spa].
An unexpected error occurred, processing of this file has failed
'fre' is not a valid language
Advanced setting:
You can limit the total bitrate for the video.  If for example you use a client that has an upper limit of 12000 KB you can set the option video-bitrate option to something like 11000 which gives you a bit of headroom for a couple of audio tracks.
There is more that can be done with this set of scripts but lets start off with these. :)
Let me know what you guys think,
Carlo
PS I'll show you how later to pull info directly from the Plex database to know what files need converting depending on your criteria.
Do you have the instructions to pull Plex DB info for converting yet?
Also in the AutoProcess.ini there is a setting "copy to" is this to copy the output someone once it is done. If so, does it work or you disabled it? I plan to add this script to my filebot movie processing script, so i want to know what options are available via the AutoProcess.ini.
@cayars
verted\process
32bit Python.
Could have swore it was "fra" but I'm just glad you got it working.
I'll have to check my install to see if I'm running 32 or 64bit version but I thought it was 64 bit version. However, for the use in this set of scripts it won't matter at all speed wise as all the time is taken in the ffmpeg conversion/mux part of the program.
Check back to message 247.
