Cayars - Setup walk through and some tips and tricks
20Mbps is going to take a fair amount of time to transfer 24TB. Several days at least, I would suspect. And possibly much longer if there are any problems.
http://techinternets.com/copy_calc?do
24TB @ 20Mbps upload comes out at > 128 days straight :slight_smile: assuming no issues or slowdowns!
hehe, well, I wasn’t going to say months, but now wish I had… :slight_smile:
Wow dint realise it would take so long. Better to download it again I guess
Hey @cayars can your script help me automate taking mkvs with softsubs to mp4s with hardsubs?
Thanks :slight_smile:
No it will not create hard subs.
I don’t really know anyone who likes hard subs. The only reason I can possible think to do this is to avoid transcoding on platforms that would have to transcode. The problem is that if you do in fact have to transcode a show/movie that is hard coded the subs loose quality.
Carlo
Carlo
I like hard coded subs, but not because of transcoding, but the lack of support at the client level for pgs subs. I don’t really like srt subs because you loose the flair some subs (think avatar).
Hi @cayars does your version of the mp4_automator script solve the issue with setting the disposition of the new aac audio track to avoid the echo effect that is seen on iOS and Apple TV when converting with FFMPEG?
The issue is described here: https://github.com/mdhiggins/sickbeard_mp4_automator/issues/490
The issue is described here: Is the ffmpeg echo on iOS devices fixed yet? Ā· Issue #490 Ā· mdhiggins/sickbeard_mp4_automator Ā· GitHub
I don’t believe it does as I’m having my users report this issue. Doesn’t help I’ve just converted all of my media. :frowning:
Cayars if you can afford the time, we would all really appreciate a fix for it. I tried to get it working with the above but no joy. I’m too dumb when it comes to these things. :frowning:
Sorry guys never heard of this before. I guess none of my users have/use apple products. :slight_smile:
I think it’s kind of weird that apples would try and play back all the audio at one time. I think just about every other software and hardware on the planet will default to the first track if multiple are set as default.
But here nor there. I should be able to fix this.
A lot of my users are using iOS devices. It seems to set all the tracks as the default resulting in both being played at the same time due to the disposition according to the link. Most unusual! If you could fix that would be awesome. Love the script otherwise, made my life a lot easier. :slight_smile:
I have converted all my files using your script, if your able to fix this, would we be able to put already converted files through a conversion again?
I guess that depends on Cayars generosity when it comes to scripting! :slight_smile:
Hi guys,
I’m new to all this bitrate and Mbps talk. Is there a thread or article that explains how all this stuff works. I understand that the software like poison and ayars will help with the conversions but I want to know what is happening underneath the hood. Any direction is much appreciated. Many thanks!
I followed all the directions on how to organize and set up a personal media library for Sports. Everything works great except for one thing.
I cannot get custom theme music, i.e., theme.mp3 to play. My folder/file structure is similar to how the example on page 1 is for the NFL and Superbowl. In my case it’s NBA season and NBA Finals. Same scenario. I’m trying to use the NBA on NBC theme song because it’s a thousand times better and memorable than ABC/ESPN’s.
I’m following every single rule for adding a custom theme.mp3 file that Plex’s says to do - make sure Local Media Assets is checked and at the top, refreshed/rescanned Library, quit/restarted Plex, looked out for special characters, sample rate 44.1k, file is only 426k, song is only 25sec. Everything.
I’m wondering if the problem may lie in the Extended Personal Media Shows Scanner or Agent now.
Any help would be great.
Man, I’m glad I reviewed this thread, I was just getting ready to start tearing through my library and converting. I’ve got quite a few on iOS
Whilst Cayars works on a fix for this issue, have a look at this thread, i have fixed most of my existing media using this method.
https://forums.plex.tv/discussion/comment/1193452/#Comment_1193452
Hey guys, sorry but I haven’t been around much lately.
Give me a couple of days to get into the flow of things and I’ll take a look at the scripts. Can’t imagine it will be hard to fix.
Carlo
Carlo
That’s ok! Thanks for doing all that you do! I’m sure looking forward to the resolution. :slight_smile: Will you include a script that will reselect track 1 as the default and leave the secondary as track 2 for the files we have already converted?
Yes I’m sure.
Most likely I’ll fix it so that moving forward ios won’t have the problem. Then I’ll create a script to identify all items in your present database in MP4 that have more than one audio track. This would then allow those items to be remuxed (no loss in quality).
I don’t have any ios devices so it’s going to be hard to test. :slight_smile:
Carlo
@cayars said:
Yes I’m sure.
Carlo
Amazeballs. It is seemingly not a problem in iOS in the sense that it’s a FFMPEG problem as it shouldn’t allow you to set 2 tracks as both the defaults AFAIK from what I’ve read from the previous posts.
