I owned this NAS Asustor AS-5304T ( Celeron J4105 )
Can somebody explain me difference between this CPU J4105 and older J3455 ?
Is there any benefit for Plex Server ?
Because I am not very happy with the Asustor SW and If I go for downgrade to NAS J3455, If I am missing something ?
Because actually also this device is not capable to HW transcode 4k H264 video from my DJI cam. ( this is maybe due to actual bug)
Video is buffering every 5 seconds of play, also video is blurring (sometimes, not all time) and loading is around 10 seconds for each buffer.
You haven’t said what your client is so that leads me to believe you are using it for play back as well. Given the High Bitrate 4K you should be looking at something with an i3 or higher like the TVS-672xt. Reason, the J’s will fall down when it comes to HD audio.
As I recall the first, second and third rule of 4k was to use direct play. Also TVs typically have a 100 meg ethernet which can cuase a lot of problems streaming the 4k bitrate.
Yes , I was try, there is all direct setuped, but I don’t know why is transcoded.
Even via USB disk TV can play it smoothly. so no idea why is transcoded
Need to look at the Plex client settings on the TV, it said it wasn’t set for direct play.
Since you have a Plex Pass you can go to https://app.plex.tv/desktop with a browser and check the dashboard for what is being transcoded.
Jan 30, 2020 14:37:19.621 [0x7fca3bfff700] DEBUG - Codecs: Testing with profile 'High'
Jan 30, 2020 14:37:19.622 [0x7fca3bfff700] DEBUG - Scaled up video bitrate to 149910Kbps based on 1.500000x fudge factor.
Jan 30, 2020 14:37:19.622 [0x7fca3bfff700] DEBUG - MDE: Selected protocol dash; container: mp4
Jan 30, 2020 14:37:19.622 [0x7fca3bfff700] DEBUG - MDE: analyzing media item 796
Jan 30, 2020 14:37:19.622 [0x7fca3bfff700] DEBUG - MDE: DJI_0045 (2019): Direct Play is disabled
Jan 30, 2020 14:37:19.622 [0x7fca3bfff700] DEBUG - MDE: DJI_0045 (2019): media must be transcoded in order to use the dash protocol
Jan 30, 2020 14:37:19.622 [0x7fca3bfff700] DEBUG - DJI_0045 - video.bitrate limitation applies: 99940 > 20000
Jan 30, 2020 14:37:19.622 [0x7fca3bfff700] DEBUG - MDE: DJI_0045 (2019): no remuxable profile found, so video stream will be transcoded
Jan 30, 2020 14:37:19.622 [0x7fca3bfff700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Jan 30, 2020 14:37:19.622 [0x7fca3bfff700] DEBUG - Codecs: testing h264 (decoder) with hwdevice vaapi
Jan 30, 2020 14:37:19.622 [0x7fca3bfff700] DEBUG - Codecs: hardware transcoding: testing API vaapi
Look for a setting limiting bandwidth to 20 Mbps. Change it to the highest value, usually Maximum or Original. DJI_0045 - video.bitrate limitation applies: 99940 > 20000
The graphics cores are the same but the supporting chips are different. The J4105 picks up improvements some which aren’t used by Plex like DRM and HDMI2.0a. The VP9 10-bit Profile2 hardware decode could be depending on media.
J3455 vs J4105
Decode / Encode
Codec h264
Decode / Encode
Decode
Codec JPEG
Decode
Decode
Codec h265 8bit
Decode / Encode
Decode
Codec h265 10bit
Decode / Encode
Decode / Encode
Codec VP8
Decode / Encode
Decode
Codec VP9
Decode / Encode
Decode
Codec VC-1
Decode
Decode / Encode
Codec AVC
Decode / Encode
As I already pointed out, the J3455 doesn’t have enough CPU capability for HD audio.
